Author Topic: fml carb help pleaseeeeeee lots of pics!!!  (Read 5937 times)
Offline xsmooth69x
« on: March 23, 2012, 03:20:30 PM »
ok i took my carbs off and totally raped my green paint but it still looks good when its back on
anyways i need help adjusting my carbs correctly
from the shop manual i got this much so far
when the throttle is fully open there is supposed to be a 1mm lip showing.
but at that level the open throttle screw is practically screwed in all the way
this is what it looks like closed. i hope there is supposed to be a gap like that
next is the butterfly flap things
i leveled all of them and they should be good. this is an open pic
closed pic
now this is another problem when the throttle is completely closed the idle screw, screwed in all the way doesn't even touch the closed carbs
so ya i have no idea what im doing
thanks for the help
« Last Edit: March 23, 2012, 03:29:07 PM by xsmooth69x »
1975 CB550 (FINISHED?!?!?)
Re: fml carb help pleaseeeeeee
« Reply #1 on: March 23, 2012, 03:27:27 PM »
Shucks ---  I was hoping for another movie like the clutch  :)
Offline xsmooth69x
« Reply #2 on: March 23, 2012, 03:28:50 PM »
i posted 2 videos on my clutch thread the cable length was good now i think my clutch is messed up
Offline LesterPiglet
  • 1977 CB550F2
Re: fml carb help pleaseeeeeee lots of pics!!!
« Reply #3 on: March 23, 2012, 03:46:01 PM »
I love your descriptions.  ;D
Offline Dimitri13
  • 1974 CB550K
« Reply #4 on: March 24, 2012, 04:22:30 AM »
1. Bench sync them. Take a 1/8" drill bit and stick it between the slide and carb body on the side that has the higher part of the slide. Adjust the slide height using the screw with the lock nut attached.
2. Put the carbs back on the bike.
3. Sync with with a carb sync tool. One of the carbs should be adjusted all the way down from when you bench synced them. That's the "master carb." Sync the rest of the carbs to that one's level.
There's some good info in this thread: http://forums.sohc4.net/index.php?topic=98188.0
Offline xsmooth69x
« Reply #5 on: March 25, 2012, 03:11:30 PM »
so other than the drill bit part everything else looks normal?
Offline xsmooth69x
« Reply #6 on: March 25, 2012, 03:35:25 PM »
also what is this supposed to be adjusted to? every time it moves it messes up that 1/8 drill bit bench sync
in the manual there is supposed to be a couple millimeter gap but no matter what it touches in every position
Offline xsmooth69x
« Reply #7 on: March 26, 2012, 08:12:42 AM »
bump
Offline lrutt
« Reply #8 on: March 26, 2012, 10:02:24 AM »
ur bike is pissed that you painted it Kawasaki green.
Offline WarwickE36
« Reply #9 on: March 26, 2012, 10:10:32 AM »
+1 for pissed at the Kawi color... paint it Honda red you'll be good
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
« Reply #10 on: March 26, 2012, 10:22:31 AM »
Here's the method i'd follow...
First, turn your idle set screw in so it touches the lever, then turn it in 1/2 turn.
this will allow the slides full range of motion AFTER your bench sync.
take the tops caps off all of your carbs so you can adjust all your slides to the 1/8" bit, and complete your bench sync.
dont worry about your throttle cable mechanism, its meant to move the slides.  just get them bench sync'd, repainted red, reinstalled, and then properly vacuum sync'd.  ;D
Done.
Offline lucky
« Reply #11 on: March 26, 2012, 10:28:57 AM »
That pin limits the throttle travel when open all the way.
Offline nayto550
« Reply #12 on: March 26, 2012, 11:14:46 AM »
A little off topic, but what kind of paint did you use on the carb bodies?
1976 CB550F
1976 CB750F - in resurrection process
1988 HD FLHS
« Reply #13 on: March 26, 2012, 12:39:55 PM »
back the idle stopper screw out,you have it wound too far in, so its end is away from the stopper flush with the threads its in,then adjust those little screws that you adjust to sync so the slides go down,have the return spring hooked up,as they drop down thats when you insert your drill bit,i like to watch through them as the light goes out one by one,then adjust the idle screw till you just see light break through,,this will run the bike and they must then be vacuum synced,if you start the bike with the carbs like you have then now itll do a million revs,you got the choke plates done ok,these are closed and choke off the air for rich cold starting.
« Last Edit: March 26, 2012, 12:42:24 PM by dave500 »
Offline xsmooth69x
« Reply #14 on: March 26, 2012, 02:41:31 PM »
agh damn it the carbs are on the bike.
i think everything was good though when i had the bike going all the carbs where at 10psi idk it was at the 10 mark on the gauges and all of them where very close to each other.
i will have to resurrect this thread probably from the dead because my Tach is broken on the bike. so when i rebuild or buy another one then i can propery sync these bad boys because from what i understand the bike has to be idling around 1500-2000 rpm.
Offline xsmooth69x
« Reply #15 on: March 26, 2012, 02:44:19 PM »
hahahah its nothing special. all the paint on the bike other than the VHT engine paint is home depot.
i used the florescent green paint and after that shot it with some automotive clear. (not the expensive 2 parts stuff just the cheap stuff)
i dont intend any of my paint on the bike to be professional. i already chipped the tell out of the carbs putting them in and out of the bike. i just simply go back with a nice paint brush and squirt the spray paint on a piece a cardboard and go picasso on it
« Reply #16 on: March 27, 2012, 12:40:45 AM »
you can still do it,wind the adjusters in the direction that lowers the slide,watch the lifting lever go down and as it stops,,stop winding,do that on all the carbs,then you can start the bike,bring the idle screw up and sync them properly,a smooth idle speed is all you need,you dont really need a tacho,you will have to wind the idle screw down maybe as you go as the rpm may increase.
Offline xsmooth69x
« Reply #17 on: March 27, 2012, 01:00:27 AM »
what adjuster are we talking about? lol
« Reply #18 on: March 27, 2012, 01:49:19 AM »
the vac sync adjusting screws,,just bring it over ill do it for you.
