Author Topic: polishing while waitin for parts  (Read 3018 times)
Offline DavePhipps
    • Hillside Technology
« on: March 25, 2012, 07:27:41 AM »
Heres my results from last nights polishing effortd\s. I still don't quiye have that mirror finish I.m looking for but it's a pretty god start.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline nayto550
Re: polishing while waitin for parts
« Reply #1 on: March 25, 2012, 08:16:59 AM »
Looking good, I've been doing the same thing.  So much tedious work, but so worth it in the end.  I've got a fork lower that I've been working on for about 20 hours now, and it's finally [almost ::)] ready for buffing.
1976 CB550F
1976 CB750F - in resurrection process
1988 HD FLHS
Offline mrrch
« Reply #2 on: March 25, 2012, 08:25:54 AM »
20 hours!
How bad was it to start with?
Polishing is satisfying work.
my build
Offline nayto550
« Reply #3 on: March 25, 2012, 08:54:46 AM »
It wasn't super bad, but it wasn't really good either.  Lots of little nicks that needed to be ground out and scratches that required the hours and hours of tedious sanding.  And I decided since I was going to polish the for lowers, I should file/grind as mush of the casting marks as I could, so that added time too.  They will be mirror finish polish when I'm finished hitting them on the buffing wheels.   But sooooo much work.  :P
1976 CB550F
1988 HD FLHS
Offline crazypj
  • I'm brill, me
« Reply #4 on: March 25, 2012, 09:19:34 AM »
Yep, good polish aint easy or quick.
 I have about 80~100 hrs in the forks I polished.
Starting with painted forks probably wasn't the best way to go but they do look good now (painted forks still had lot of casting marks, part lines, corrosion pits, etc)
Used file then 80 grit to get things smooth then worked down to 600 before polishing on buffer
They are now real 'mirror finish'
Offline Bailgang
  • Scott
  • Indiana
« Reply #5 on: March 25, 2012, 09:33:45 AM »
Is that the old grimy filthy cover I sent you? Geez, you have been busy!!
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline Bailgang
  • Scott
  • Indiana
« Reply #6 on: March 25, 2012, 09:37:55 AM »
If it's the same cover I sent him, it was nasty. :)
Scott
71 cb350 twin
77 cb750 F2
Offline DavePhipps
« Reply #7 on: March 25, 2012, 10:54:23 AM »
Yep, same cover after about 3 hours of work. I still can't get the fine buffing swirls out though.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline Johnie
« Reply #8 on: March 25, 2012, 11:16:15 AM »
Today I started the process of polishing the oxidation off the side engine covers. A slow, tedious and very messy deal, but well worth the look in the end. So far I hit it with the red rouge. Next comes the green and then white will finish it up. Once that is done my pipes should be here and ready to install for the final leg of this fun K3 project.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline kck3
« Reply #9 on: March 25, 2012, 11:29:45 AM »
Johnie-did you keep those covers on the bike or remove them for polishing?
Offline Really?
« Reply #10 on: March 25, 2012, 12:10:36 PM »
The two most PITA parts I found are the brake hub and the forks lowers.  The brake hub you can go over and over and over and over and just not feel satisfied.  The fork lowers have a lot of casting marks, I filed and used a stone wheel/dremel on the fork lowers before I really got into the sanding part.  You can see the rear hub in my sig.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Really?
« Reply #11 on: March 25, 2012, 12:17:07 PM »
Before and after of the fork lowers.
Before
After
Offline Johnie
« Reply #12 on: March 25, 2012, 04:05:26 PM »
kck3...this bike I left the covers on and polished them outside. I figured since there was no leaks and the bike only has 5,310 miles on it I would leave them on this time and see how it comes out. I first took the clear off. When I was done with the red rouge I used the Dremel in the places I could not reach with the wheel. The forks in this picture I did off the bike. The last pic is a shot of the left before I started and the right one was after the first pass with the red rouge.
« Last Edit: March 25, 2012, 04:09:14 PM by Johnie »
Oshkosh, WI  USA
Offline DavePhipps
« Reply #13 on: March 25, 2012, 04:25:58 PM »
I hope mine turns out as well as yours. What do you use to get rid of fine swirl marks?
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline Johnie
« Reply #14 on: March 25, 2012, 04:34:46 PM »
By the time I am done with the white rouge swirl marks are about gone. I find Semichrome or MAAS does a good job on it too. I think the main thing is to not rush the job, but take your time and let the rouge do the work.
Oshkosh, WI  USA
Offline Robaholic
« Reply #15 on: March 25, 2012, 06:36:24 PM »
Those look great!
Are you doing the sanding by hand?
Offline DavePhipps
« Reply #16 on: March 25, 2012, 06:41:42 PM »
I'm sanding with 400 wet/dry then working my way through the polishes.
I just went out and did an experiment. I wet sanded with 2000 then 3000. I'm getting a much better reflection now. I'm not sure what grit my polishes are, but they don't seem to be as fine as I need. I got them with the eastwood kit
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline Really?
« Reply #17 on: March 25, 2012, 07:52:27 PM »
I've taken mine to 2000 then used the polishing rouge to get a better shine.
Sent from my chalkboard using a tickler.
Offline crazypj
  • I'm brill, me
« Reply #18 on: March 26, 2012, 09:17:38 PM »
I don't tend to go finer than 600, then 'black' (emery compound ) on stitched mop followed by 'red' compound on a loose mop.
 Vary the pressure to get a better finish.
If it isn't shiny enough, you may have to start over at 600 grit, polishing shows any flaws you left behind on earlier 'finished' stages (which is why my forks took so long  ::))
