Author Topic: Mongrel  (Read 41475 times)
Offline Damage Inc
Re: Mongrel
« Reply #100 on: October 15, 2014, 07:04:16 PM »
Gday Damage, are you fitting rear sets to the bike..?  These bikes are horrible with clip ons and stock pegs, ergonomics are all wrong, stock pegs are too far forward and its as uncomfortable as hell, been there done that, if you are running rearsets then you its a bit better but in all seriousness, these bikes aren't really designed to work with clip ons, thats why the CR race bikes have a very long tank, look at the post classic racers, they all use superbike style bars, which clear the tank..... ;)
I'm hearing you, yes have planned all along to have rear sets fitted, and expect a less than comfortable ride. I may have made an error with the bars I've chosen, they are designed for a track bike. I will find it hard to change direction as I'm prone to be a bit "tight".
"100" today :o
There is nothing Man makes, that Man can't break.
Re: Mongrel
« Reply #101 on: October 15, 2014, 07:59:02 PM »
Nice looking custom work 'Damage Inc.'  8)
Thx grcamna2, it's been a slow process. I feel like I'm getting the look I'm after. I'm looking forward to the day I ride it, and that's my motivation.
If you want clip-ons and to retain the stock tank, get some that have a rise to them and are adjustable in the "pull back". It should allow you to have the best of all worlds.
Thx calj737, unfortunately I already have some clip-ons and they aren't of the adjustable variety. I suppose I could consider resale and update to a adjustable set. That's an option.
I like the name of your thread 'Mongrel' ; a 'mongrel' to me is known for having the best mix of interbreeding DNA to make it one of the toughest 'Dogs' out there  ;D
I like your use of strong steel parts which speaks to me of durability over the long haul  8)  ;)
Offline Damage Inc
Re: Mongrel
« Reply #102 on: October 15, 2014, 10:46:23 PM »
G'day Retro
I some how answered your post before I received it.
Re: Mongrel
« Reply #103 on: October 16, 2014, 12:38:14 AM »
G'day Retro
 ;D ;D ;D :o
Offline Damage Inc
Re: Mongrel
« Reply #104 on: October 16, 2014, 01:57:35 AM »
I'm impressed with your description of a "mongrel", if it lives up to it, I'll be more than happy. I'm a structural steel fabricator by trade, so I tend to over engineer things. One of my driving motivations to start this build, is to build some different exhaust systems for it and I think they could define the "Mongrel"
Offline Damage Inc
Re: Mongrel
« Reply #105 on: November 01, 2014, 09:07:08 PM »
I've been assembling my carbs and noticed that the throttle valves aren't all level with each other. I'm assuming that they should be.
Do I get them level by adjusting the "adjuster holder"?
Top photo shows the different levels.
Offline goldarrow
  • one day, i'll be an
Re: Mongrel
« Reply #106 on: November 01, 2014, 09:09:06 PM »
This is when bench synch, then vacuum gauge synch come in to play.
CB550 K0
Offline Damage Inc
Re: Mongrel
« Reply #107 on: November 01, 2014, 09:22:28 PM »
Ahhh
Thank you very much goldarrow.
Offline Damage Inc
Re: Mongrel
« Reply #108 on: November 03, 2014, 02:13:32 AM »
Finished my carby assembly tonight, took me a while to figure out how to get the bowl orings to stay in place.
Moving on to splitting the engine case next.
Deep breath, here goes!
Offline Damage Inc
Re: Mongrel
« Reply #109 on: November 14, 2014, 02:41:57 AM »
So it appears that the last po to adjust these case bolts, tensioned them with an axe.
I can't get a socket or spanner to grip 2 bolts that look like this one.
Any ideas on how to get them out? I'm not quite ready to weld a nut onto it. Perhaps a pair of vice grips or locking pliers.
Offline Restoration Fan
  • My wife will never call me
Re: Mongrel
« Reply #110 on: November 14, 2014, 06:13:27 AM »
I would try vice grips on it first.  If that doesn't work, why not just go ahead and use your nut-welding technique?  After all, you're not going to want to reuse that bolt anyway.
FWIW, you can purchase entire sets of replacement bolts for pretty reasonable prices on eBay.  I know that you still have shipping costs to incur with shipping to Australia that we didn't have to consider though.
Offline Damage Inc
Re: Mongrel
« Reply #111 on: November 15, 2014, 02:30:50 AM »
Good point calj737, heat always helps.
Thx Restoration Fan
I've got the new s/s fasteners for the covers, but I'll look into the engine bolt kits. Some of the philipsheads are pretty grotty as well.
Offline Damage Inc
Re: Mongrel
« Reply #112 on: November 15, 2014, 04:21:25 AM »
They're not Phillips, they're JIS. The reason they look grotty is lunkheads before you used Phillips bits on them trying to turn them out and in. If you replace them with SS, use some Antiseize on the threads when screwing SS into aluminum.
AlloyBoltz.com has complete kits for about $35 all labeled in separate little baggies for you,
JIS you say!  Thx didn't know that one.
I've got more than a lifetimes supply of nickel based antiseize. I think that's the best for s/s in aluminium.
Will be sure to check that site out thx again.
Offline Damage Inc
Re: Mongrel
« Reply #113 on: November 17, 2014, 02:02:04 AM »
I looked at the site and the kits I found were similar, if not the same as what I already have. They do the covers on the sides and head. I'd be interested in a kit for the upper and lower case. Have you seen one of these and I'm just missing it? I was wondering if Allen heads would even be suitable, considering the tensioning required.
Offline Damage Inc
Re: Mongrel
« Reply #114 on: November 17, 2014, 02:50:04 AM »
Having some difficulty separating the cases, I think all relevant bolts are out. There is 2 in top photo which I don't think that they needed to be removed yet. The" tap lightly with a wooden hammer" is having no effect. Who knows what they've been glued together with previously!
Offline Damage Inc
Re: Mongrel
« Reply #115 on: November 18, 2014, 04:32:01 AM »
Still having problem splitting these cases!
No amount of hammering , with a nylon hammer. Not getting any movement.
Some tips or tricks would be appreciated.
Re: Mongrel
« Reply #116 on: November 18, 2014, 11:05:38 AM »
possibly soak the whole bottom end in a tank of warm fluid for a while?
Offline Kemp
Re: Mongrel
« Reply #117 on: November 18, 2014, 12:54:27 PM »
bet there is one bolt still holding it together!!
Offline Damage Inc
Re: Mongrel
« Reply #118 on: November 18, 2014, 11:10:33 PM »
Is someone running a book? Your probably on the favourite there. If there is an internal bolt that would be it..
There is only the two large bolts externally that haven't been removed, which you see in the top picture
Offline Damage Inc
Re: Mongrel
« Reply #119 on: November 19, 2014, 01:49:27 AM »
And the winner is "Kemp".
One internal bolt I missed in the manual.
2 taps and split.
Thx guys for your tips.
Offline Damage Inc
Re: Mongrel
« Reply #120 on: November 20, 2014, 10:44:44 PM »
Today I've dropped the crank and conrods off to the engine shop, to be balanced. They said that they'll clean up the bearing surfaces as well.
So I've decided to replace the main and big end bearings, while I'm at it.
Re: Mongrel
« Reply #121 on: November 21, 2014, 06:32:49 AM »
2 taps and split.
That's good you found it rather than pulling your hair out  :)
Offline Damage Inc
Re: Mongrel
« Reply #122 on: November 21, 2014, 03:17:29 PM »
2 taps and split.
I'm glad I resisted the urge to follow the advise of a friend to drive a flat head screwdriver between the cases.
I want to remove this bearing before I pressure wash and paint strip the case. Thinking a bit of heat and it may drop out. The slide hammer didn't move it.
Offline Damage Inc
Re: Mongrel
« Reply #123 on: December 02, 2014, 03:13:11 PM »
I've been removing paint from the engine cases and the sump cover. One of the fins on the cover is ground down.
Is this normal and required for some clearance? If not I'll build it up to match the others.
How prone are the head studs to stretching? Is there merit in replacing them?
Re: Mongrel
« Reply #124 on: December 02, 2014, 10:08:55 PM »
The studs are prone to stretch. HD studs will allow you to torque down the head tighter. In my case, it cured a leak issue.
