Author Topic: CB550 lower end knock video HELP  (Read 5484 times)
Offline Flying J
« on: March 31, 2012, 03:09:58 PM »
 Here is a video. Its sound a little worse in the video then it actually is but its lower end knock that goes away as the rpms hit about 3k. Im not sure what is causing it.
Cb550 engine knock
Offline geminimotors
Re: CB550 lower end knock video HELP
« Reply #1 on: March 31, 2012, 03:30:16 PM »
I have a similar issue with my 76 550F. It goes away at about 2k. I'm curious to hear what people think.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: March 31, 2012, 03:30:36 PM »
Did this just start or has it been going for a while? Clutch or primary chain is my guess.
« Reply #3 on: March 31, 2012, 03:43:42 PM »
I just went out and had a look at mine. The noise had gotten progressively worse in the last two weeks. The three bolts attaching the stator to the cover were loose. Tightened them up and the noise quieted down significantly. There is still something faintly rattling in the bottom end that goes away at about 1800 rpm.
Offline LBM 550F
« Reply #4 on: March 31, 2012, 03:51:06 PM »
Sounds like a exhaust leak to me, Is the bottom rusted through one of those pipes?
        L.
  • 1977 CB550F2
« Reply #5 on: March 31, 2012, 03:57:13 PM »
And the exhaust leak seals itself @3000 rpm!
Offline Flying J
« Reply #6 on: March 31, 2012, 04:00:11 PM »
No, its a knock coming from the motor not the exhaust.
  • 1977 CB550F2
« Reply #7 on: March 31, 2012, 04:04:10 PM »
Any difference in sound when you pull the clutch in?
Offline Flying J
« Reply #8 on: March 31, 2012, 06:03:46 PM »
No, but it sounds very similar to that clutch noise but louder. I checked the 3 screws under the left cover. They were tight.
Im wondering if this is what the primary chain sounds like.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #9 on: March 31, 2012, 06:08:26 PM »
That would be one of my first guesses, considering 'we' don't think it's the clutch rattle, misadjusted valves, or an exhaust leak..I also think that when the rpms go up, the tension on the primary chains would increase, and that may be enough to pull the chain from the interior wall of the case.
Have you pulled the pan to check if it's rubbing?
« Reply #10 on: March 31, 2012, 08:07:42 PM »
Don't run it anymore until you synch your carbs! At least eliminate one potential problem.
Offline Flying J
« Reply #11 on: March 31, 2012, 08:21:44 PM »
They are synced. But i wonder if one rattled lose. I'll have to double check that.
Offline Flying J
« Reply #12 on: April 01, 2012, 08:13:37 AM »
Bwaller you may be right on the money. I went out last night and checked sync adjustment screws and the #1 was lose. When I'm free this afternoon I'll check the sync and see how far that one has wandered. If that's it i will be so happy.
« Reply #13 on: April 01, 2012, 08:20:33 AM »
Here's hoping you're riding with a smile on your face this afternoon.  ;)
Offline WarwickE36
« Reply #14 on: April 01, 2012, 03:07:51 PM »
My primary chain made some noise very similar to that.  Check my posts, I have videos of it with the oil pan pulled, then with the motor pulled with the cases split and then again with the new chain for comparison.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline Flying J
« Reply #15 on: April 01, 2012, 09:15:03 PM »
Syncing the carbs helped a bunch. It still has a little knock but not bad. I will check the primary chain next time i change the oil. The bike ran fine for a few blocks but then got real jerky in mid range throttle. Then it got even worse. The exhaust smelled like fuel. checked the plugs, 1&2 they were black. So i dropped the bowls.
I think i need to do a better job tightening things down.
« Reply #16 on: April 01, 2012, 09:21:45 PM »
ff,
  That's a clue..for sure ! ::) Is that Permatex "High Tack" gasket sealer that I notice around the bowl gaskets ?  if so..that could be part of the problem.It may be getting into you're pilot jets. I think you should clean up the pilot circuit & jets real good & don't use any gasket sealer on you're carb. bowls..just the standard,pliable gaskets.
« Reply #17 on: April 01, 2012, 09:29:26 PM »
...really doesn't matter if jets are clean or plugged when they are sitting in the bottom of the float bowl ;)
« Reply #18 on: April 01, 2012, 09:32:00 PM »
I'm with you there !
Offline Flying J
« Reply #19 on: April 01, 2012, 09:51:03 PM »
ff,
Not sure what it was but it's just residual and would be real hard to scrub off. Its not getting into the bowls. The carbs are clean and I have not had any problems with junk in the carbs since i put on a petcock with a filter. These last 2 problems have be my own fault. Ill be gone for my anniversary for a few days but when i get back ill ride the hell out of this bike and see what problems i can turn up. Thats generally how i do it.
