Author Topic: Black Jack 1978 K8 750cc  (Read 20317 times)
Offline Familyvan
Re: Black Jack 1978 K8 750cc
« Reply #50 on: August 15, 2013, 05:11:13 PM »
Yes I have a small oil cooler going on the front of the bike
Not the best picture but you get the idea.
Offline Familyvan
« Reply #51 on: August 18, 2013, 04:21:35 PM »
Engine build coming along nicely. Hoping to have the barrels and head on tomorrow night.
Offline Familyvan
« Reply #52 on: August 26, 2013, 12:55:32 PM »
So the next problem is as follows
The new conrods are rubbing on the bottom of the barrels
Do I trim the bottom of the barrel sleeves
Or
Shave some off the con rods , however they have all been balanced ??
Please help
Offline iron_worker
« Reply #53 on: August 26, 2013, 01:45:44 PM »
I would think it would be better to shave the barrels and try to keep all the strength you can in those rods. I'm not an expert though that just makes sense in my head. The bottom end of the barrels aren't subject to a lot of load ... the rods are.
IW
Offline Familyvan
« Reply #54 on: August 26, 2013, 01:57:21 PM »
Thanks Iron, I've just got a text back from my engineer and he suggests the same.
So that's what I'll be doing. Hopefully
Offline Familyvan
« Reply #55 on: August 27, 2013, 12:33:35 PM »
So I notched the 2+3 sleeves but notice a slight rubbing from the 1+4
So I ended up notching all 4
Engine now turns over freely
Onto the next problem that turns up lol  :D
Offline KrautKoffin
« Reply #56 on: August 27, 2013, 01:23:31 PM »
What am I missing here? Did you just cut it and put in a sleeve with Allen screws to hold it in? Pardon me for being dense  ;D
74 cb550
I now have Beastie Boys "Sabotage" stuck in my head after seeing your avatar.
Offline iron_worker
« Reply #57 on: August 28, 2013, 11:28:27 AM »
Interesting ... I'm also an engineer. lol
Just make sure those edges are deburred so the rings don't catch on them as you're installing the cylinders.
IW
Offline Jayhawk
« Reply #58 on: August 29, 2013, 06:01:22 AM »
IW
I agree; make that 2 engineers.  There must be a joke there somewhere.  ;)
As IW advised, make sure the inner edge of the sleeve is carefully chamfered \ deburred, as it would suck to catch a ring, or more likely, scratch the ring surface during assembly, and end up with compromised ring seal.
Offline Familyvan
« Reply #59 on: August 30, 2013, 11:56:20 AM »
What is the length of the 4 bolts shown in figure 12 ?
Thanks having a nightmare finding them.
Offline Familyvan
« Reply #60 on: August 30, 2013, 01:15:35 PM »
Thanks for the advice regarding de blurring the barrel sleeves all done thanks
Next problem
I didn't make a not of which cam carrier went where.
New cam is being fitted.
Any tips or advice.
Offline KrautKoffin
« Reply #61 on: August 31, 2013, 01:10:30 PM »
Guess so..
74 cb550
Offline LesterPiglet
  • 1977 CB550F2
« Reply #62 on: August 31, 2013, 02:27:56 PM »
^^^ Gordons Frame Kit.
Offline Familyvan
« Reply #63 on: August 31, 2013, 02:39:31 PM »
Yes a Gordon frame kit.
Simple design , easy to instal make removing the engine a lot easier.
Offline KrautKoffin
« Reply #64 on: August 31, 2013, 02:41:33 PM »
Sweet
74 cb550
Offline Familyvan
« Reply #65 on: September 01, 2013, 02:07:18 AM »
I think I bought it from cycle X
« Reply #66 on: September 01, 2013, 07:26:47 AM »
 Yes a bit different than the Gordon kit.
Offline Familyvan
« Reply #67 on: September 01, 2013, 11:55:45 AM »
Well I have built up the engine to getting the cam in. I have managed to get the timing right. I think. But when I have gone to put the can wheel onto the cam the cam chain is too tight
I have not installed the cam tensioner yet!
Any ideas. I'm hoping it not the cam chain come off at the bottom on the crank. I have turned the engine over and the cam chain does move.
Any ideas please.
Offline Familyvan
« Reply #68 on: September 01, 2013, 12:44:56 PM »
Panic over I applied a little pressure then it went on!!
However I forgot the locating dowels for the cam holders so it all has to come off. Lol
Offline Familyvan
« Reply #69 on: September 03, 2013, 01:27:24 PM »
Now bear with me. If you've been following my thread you'll see I'm a complete idiot an new to engine building
I thought I had the cam in the right way, but when I came to do the valve adjustments I noticed that the no 4 port where down when the cam love is up. Should the no.1 lobes be down??
  • 1977 CB550F2
« Reply #70 on: September 03, 2013, 02:34:25 PM »
Rotate the engine another 360.
Offline Familyvan
« Reply #71 on: September 04, 2013, 01:03:08 AM »
Thanks lester, I suspect I should be feeling like a plum right now.
Thanks again.
Offline Familyvan
« Reply #72 on: September 06, 2013, 02:49:09 AM »
Offline Familyvan
« Reply #73 on: September 12, 2013, 08:37:40 AM »
So I finished last night but had to get up with the kids so had a few hours to kill decided to drill the rear disc
Downloaded a pattern off this forum and set too
Template mounted on disc
Rear rotor drilled and placed in lathe to de bur with sandpaper
Completed produced. Only took an hour of drilling.
Offline Familyvan
« Reply #74 on: September 12, 2013, 12:26:51 PM »
Rear wheel now in. Still waiting for new pistons for rear caliper
