Author Topic: Black Jack 1978 K8 750cc  (Read 20373 times)
Re: Black Jack 1978 K8 750cc
« Reply #75 on: September 12, 2013, 01:30:10 PM »
Where is the swingarm from?
Offline Familyvan
« Reply #76 on: September 12, 2013, 02:34:34 PM »
It's a Dresda swing arm, bought on EBay.
New bearings
Offline Familyvan
« Reply #77 on: September 13, 2013, 07:54:52 PM »
So today's daily crisis consisted of modifying the speedo bracket as with the new yoke from a honda Gl1000 the holes on the speedo bracket didnt line up.
So now that problem is solved pictures to follow.
Next problem came when trying to fit the new coils I have
The new coils have electronic spades which get into the way of the brackets see below
Where the old coils didnt have any
So it looks like I'm going have to notch the backer
Offline Familyvan
Re: Black Jack 1978 K8 750cc wiring help!!
« Reply #78 on: September 23, 2013, 04:25:14 PM »
Well I've made a start on my wiring nightmare
I have a 1978 new wiring loom and have managed to make a "good go of it"
However I could do with a little help in identifying these wires
Thanks
Offline Familyvan
« Reply #79 on: September 25, 2013, 02:06:58 PM »
New custom handmade seat, trail fitting
Offline Familyvan
« Reply #80 on: September 25, 2013, 02:08:42 PM »
What has everyone else done in regards to there old regulator
I have a new regulator rectifier
Is there a modern smaller alternative for the regulator
Offline epskate
« Reply #81 on: September 25, 2013, 02:57:47 PM »
I could be totally wrong, but I think I've seem someone using an R1 regulator/rectifier.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #82 on: September 26, 2013, 03:44:59 AM »
Lots of folks have replaced the R/R with a modern piece easily available, try the search top left.
Why? If it ain't broke don't fix it.
Offline Familyvan
« Reply #83 on: October 02, 2013, 12:26:05 PM »
« Reply #84 on: October 02, 2013, 08:12:34 PM »
Familyvan,
I really like the look of your bike.  My K7 is similar -- to the extent I am using a Super Sport tank and a GL1000 front.  That Dresda Swingarm is awesome.  Only in the UK can you find one of those on ebay or an autojumble.  Here, they are RARE.  I like the conversion to rear disc brake.  I'm wondering why you are using Super Sport (F) sidecovers.  Just to match with the tank and rear disc brake?
Also, what's the story with the VFR800 front discs.  Did they directly bolt onto the stock front hub?  Did you need any spacers to match the GL1000 front calipers??
Offline Familyvan
« Reply #85 on: October 03, 2013, 08:21:14 AM »
In regards to the side panels I liked them because they look smoother and flow better with the bike.
The VFR discs only needed a little re drilling in order to assist bolting to the hubs. I have had to make some adapters to bolt to calipers to the forks
I may need to do some additional work regarding the speedo and cable but I only time will tell.
  • 1977 CB550F2
« Reply #86 on: October 04, 2013, 03:23:34 PM »
Are your old coils faulty? Are you keeping them? If you would like to part with them I would be interested. PM me.
  • 1977 CB550F2
« Reply #87 on: October 04, 2013, 03:26:09 PM »
Thanks lester, I suspect I should be feeling like a plum right now.
Thanks again.
So many times.......myself I mean.
Offline Familyvan
« Reply #88 on: October 06, 2013, 10:42:15 AM »
Lester I will have a look. The bike did run before breaking it down. So they should work. Just the wiring looked tired. Will dig them out and post some pictures
On another note.
I have now got fuel and oil in the engine. When I went to fire it the starter motor was only spinning over. So I did a quick search and swapped for a second starter motor. It still does the same thing
1. Should the clutch gear spin in one direction freely when engine not moving ??
Offline Familyvan
« Reply #89 on: October 06, 2013, 11:22:35 AM »
Ok so my hand is in the air once more!! I'm an idiot. The bolt at the alternator end wa slight lose causing it to spin
Everydays a school day!! Lol
Offline Familyvan
« Reply #90 on: October 15, 2013, 06:02:06 AM »
Firing on all 4??
Offline Familyvan
« Reply #92 on: October 16, 2013, 10:29:01 PM »
So I suspected that the engine was not firing on all 4. So I did the wet finger test on the exhaust manifolds and it turns out that number 3 is hot. So have now removed the carbs to clean them after I had tested the spark on the lead and plug.
I had a feeling that I hadn't syn the carbs properly when I rebuilt them ( slight ignorance on my behalf)
So that will be my job for the weekend!!
Offline Familyvan
« Reply #93 on: October 19, 2013, 01:27:36 AM »
I love restoring stuff
I have now got all the bits required to restore the rear caliper. Which is off a 1976 750cc supersport. When I removed the old pistons they were junk. So I got my mate to make me some stainless steel new ones.
Offline Familyvan
« Reply #94 on: October 19, 2013, 04:25:41 AM »
Working progress
Complete..well nearly.
Offline bert96
  • past ride
« Reply #95 on: October 19, 2013, 04:37:38 PM »
Honda VFR 800 discs
Harley front fender
Harley fender...but which one? sportster?
bought from ebay?
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline Familyvan
« Reply #96 on: October 20, 2013, 09:58:19 AM »
I believe the front fender is a harley sporter fender. Not sure what year as my mate had it layed around and have it to me. It only required a little cutting. In order to mount it close to the wheel.
Offline Familyvan
« Reply #97 on: November 19, 2013, 06:06:26 AM »
I currently have no oil going to the cyclinder head the cam is running dry
The engine has been complety rebuild
There is oil in the tank.
Any suggestions where to start??
Offline Familyvan
« Reply #98 on: November 19, 2013, 06:12:37 AM »
Where should the feed from into the cylinder head??
Thanks in advance.
Offline Familyvan
« Reply #99 on: November 19, 2013, 06:49:40 AM »
At idle I get an oil pressure reading of 60!!
