Author Topic: MAC exhaust ruined after 2 minutes!  (Read 7046 times)
Offline 750K
Re: MAC exhaust ruined after 2 minutes!
« Reply #25 on: April 04, 2012, 08:36:55 AM »
#$%*ty deal, if it were me I'd wire wheel them down to bare metal. Repaint em with high heat and bake them, then see if I wanted to wrap them.
77 Cb750, 78 Kz1000
Offline mrrch
« Reply #26 on: April 04, 2012, 08:52:19 AM »
I bought my Mac from Niche Cycle thru their website (cheaper than their ebay listing) and had no problems with my painted exhaust(going on 2 years now). Alot of warranties have to go direct to the manufacturer nowadays. I'd call Mac again (remember to be nice/goes farther than being irate)
my build
« Reply #27 on: April 04, 2012, 09:06:46 AM »
 Try this scuff em up with emery on the bike,  mask, repaint...ride it.. end of problem.. it is just painting a header..
Offline heffay
« Reply #28 on: April 04, 2012, 09:34:22 AM »
Which will inevitably need to be redone, and redone, and redone; maybe he purchased without knowing this fact.  I'll never buy painted pipes for that reason, they never look as good as you would like, except for just after paint, and they always need "maintenance".
Offline robdrobd
  • Who? Me?
  • Isn't she a beauty?
« Reply #29 on: April 04, 2012, 09:39:04 AM »
Maybe chrome or wrap is the way to go.
Offline Roach Carver
« Reply #30 on: April 04, 2012, 10:08:32 AM »
Headers get insanely hot. Touch one and see for yourself. I know of no paint that will endure it forever. As far as im concerned no one should be without a couple cans of bbq paint. I do it every year. Not too big a deal. Ceramic coat would last longer but be more expensive. I had one done and then had cracks develop which i attributed to its decreased abilty to disssipate the heat. Who knows though.
bollingball
« Reply #31 on: April 04, 2012, 10:26:41 AM »
Will the wrap trap water if caught in the rain or while washing then start rusting under it out of site? Look up (Jet Hot) coating inside and out.
Drill some weep holes also.
Ken
Online Don R
« Reply #32 on: April 04, 2012, 10:28:23 AM »
I've used eastwoods stainless coating with OK results. The maniflds on my street rod have lasted over 20 years, they are turning darker now and could be re-done. It doesn't last as long on tube headers but better than paint. I baked the pipes by hanging them and inserting a propane torch into each tube.  Jet hot or nitroplate is almost indestructable, not cheap but a good product.
bollingball
« Reply #33 on: April 04, 2012, 10:29:37 AM »
Offline messeduptriple
« Reply #34 on: April 04, 2012, 10:49:31 AM »
Any pics of the incident??? I'm curious to see what they looked like
Sent from my PC36100 using Tapatalk
Offline robdrobd
  • Who? Me?
« Reply #35 on: April 04, 2012, 10:57:25 AM »
will post pics tonight
Offline cb650
« Reply #36 on: April 04, 2012, 01:58:26 PM »
I have two old macks and the paint is still good.  Last one was bought in 95 or so.
Offline robdrobd
  • Who? Me?
« Reply #37 on: April 04, 2012, 03:10:48 PM »
I think I may have just gotten a defective one.
« Reply #38 on: April 04, 2012, 03:23:46 PM »
If your engine is running lean (stack will do that), the exhaust temp will be several hundred degrees hotter than what is normal.
They make heat guns for removing paint.
I've seen chromed exhaust headers glow red from excessive heat.  Paint won't endure that.  The chrome turned to straw color and then blue when cooled.
Offline robdrobd
  • Who? Me?
« Reply #39 on: April 04, 2012, 04:19:50 PM »
Pics
« Reply #40 on: April 04, 2012, 04:28:47 PM »
Did the paint blister on all pipes or just some?
Is it steel or paint under what is flaking off?
Offline robdrobd
  • Who? Me?
« Reply #41 on: April 04, 2012, 04:33:23 PM »
All flaking in some spot, steel underneath.
Offline srbakker
  • Spam & Eggs
« Reply #42 on: April 04, 2012, 04:37:47 PM »
If you're gonna wrap them, spray a decent high heat clear on there first, after you get the old paint off.
1975 CB750 K5
2007 Triumph Tiger
2007 Triumph Speed Triple
1971 Kawasaki F7 175 Enduro
« Reply #43 on: April 04, 2012, 04:41:28 PM »
Just checking.  Can you tell the difference between steel and grey paint?  You may have to scratch through the surface to actually be certain.
Anyway, it wouldn't be the first Mac set to be repainted with the wrong paint, or have been burned off with exhaust temps way too high.
More work to do...  (It never really ends.)
Offline robdrobd
  • Who? Me?
« Reply #44 on: April 04, 2012, 04:47:47 PM »
Definitely bare metal under there. Doesn't even look like it had another coat other than the black.
« Reply #45 on: April 04, 2012, 05:33:51 PM »
Wow ..that sucks
Offline 750K
« Reply #46 on: April 04, 2012, 07:54:44 PM »
Well on the bright side it looks like removing the blistered paint will be easy, if you want it done right do it yourself I guess.
77 Cb750, 78 Kz1000
Offline CycleRanger
  • No comment about being an
« Reply #47 on: April 04, 2012, 07:58:54 PM »
Offline tortelvis
« Reply #48 on: April 05, 2012, 08:23:54 AM »
When I was 16 I had taken my CB450 engine out for some work and after getting it all back together and running for about 10 nimutes I thought I saw the headers vibrating as if I had not tightened them back properly. Soooo...I grabbed the chrome header to give it a bit of a shake to see if they were indeed loose. I touched one. I saw for myself. Not to be repeated for sure!
Offline EricHa
« Reply #49 on: April 05, 2012, 09:19:17 AM »
Self cleaning headers, why didn't I think of that?  :P
I read this thread exactly 10 minutes after ordering a black MAC header from Niche, so I may possibly get a self cleaning set as well. I plan to fab a Yosh type tail pipe for it, eliminating the MAC can. I've been hearing good things about John Deere muffler paint, and may try some on the pipe.
1975 Honda CB550K1
1976 Honda CB750K6
1977 Kawasaki KZ900A5
