Author Topic: Bare metal gas tank  (Read 4337 times)
Offline longshanks
Bare metal gas tank
« on: April 05, 2012, 10:22:58 AM »
So I've been wanting to go the bare metal look for some time now and I was just going to rattle can a clear coat on it after paint stripping it but after talking to different sources that seems like a bad idea. One paint professional told me it would turn yellow if it wasn't UV protected and after doing even more research it seems like powder coating clear is the best way to go. However, that sounds really expensive and most people don't like to powdercoat a gas tank because of the possibility of explosion if any latent fumes accumulate.
I don't care so much for the "niceness" of the tank. I kind of want that ratty look but I want to keep the rust out for obvious reasons. Could I get by with rattle-canning the tank every so often when needed?
cb450 K5
Offline CycleRanger
  • No comment about being an
Re: Bare metal gas tank
« Reply #1 on: April 05, 2012, 10:50:17 AM »
If you're set on bare metal powder is the way to go.
I would expect it to cost ~$100, maybe less, (depends on how much prep they have to do) or so to have a tank powder coated and anyone who says the tank might explode is an idiot or just doesn't really want your business or both. ;)
Offline longshanks
« Reply #2 on: April 05, 2012, 11:18:45 AM »
Where would be some good places to check out for powdercoating? Auto body shops? motorcycle shops?
cb450 K5
« Reply #3 on: April 05, 2012, 11:55:05 AM »
you in the US?
go to google maps
type in your zip code and hit enter.
you should see the map of you area. zoom out a little for a larger map area.
now, type in Powder coating services and hit enter.
this will show you all the powder coating places in your map.
done....
Offline Ira
« Reply #4 on: April 05, 2012, 12:14:49 PM »
My tank has been stripped bare for 2 and a half years. I didn't coat it or paint it.  It will occasionally get a spot of rust here or there, but I just rub it with wd-40 and a rag or scotchbrite pad every few months.  the bottom side is painted, but no one can see it anyway.  Picture is in my signature.
Offline Toxic
« Reply #5 on: April 05, 2012, 12:29:32 PM »
Ira  -  tank looks real nice and goes well with the overall look of your bike
Cute kid, massive dog.  LOL
Offline Ira
« Reply #6 on: April 05, 2012, 12:38:56 PM »
Thanks ;)
Offline apex_seeking
  • Ron Swanson is a
Bare metal gas tank
« Reply #7 on: April 05, 2012, 12:57:58 PM »
I just did exactly what you're talking about but I went with powder. It turned out great and there will be no explosions. My buddy did it so I can't tell you what the cost would be but $100 sounds right. And it's more durable than rattle can.
Offline nayto550
« Reply #8 on: April 05, 2012, 01:28:20 PM »
Check the phonebook or google, there's usually places that specialize in powdercoating.
Also, if you really want to try spraying clear on, I would give the SprayMax clearcoat a try.  It's a UV resistant, 2 part urethane in an aerosol can.
1976 CB550F
1976 CB750F - in resurrection process
1988 HD FLHS
Offline greenjeans
  • 1972 CB750K2
« Reply #9 on: April 05, 2012, 02:38:26 PM »
Unless you store it out side in the elements, a little WD-40 and a scotchbrite with keep the rust at bay.
Offline longshanks
« Reply #10 on: April 05, 2012, 04:14:37 PM »
you in the US?
go to google maps
done....
yes, i'm in los angeles, and yes i know how to use google maps  ;)
cb450 K5
Offline longshanks
« Reply #11 on: April 05, 2012, 04:18:07 PM »
not so sure that would be enough given that i'm right near the ocean.
cb450 K5
