Author Topic: Polishing is a Filthy and Thankless Task  (Read 4278 times)
Offline alacrity
  • Ride, Optimize, Repeat
« on: April 06, 2012, 10:50:06 PM »
So there I was polishing my petcock...
 ;D
ha ha ... that sounds dirty... and in fact it WAS!  It was filthy and filled with varnish, rust and what looked like dried Spackle.  Yeccch.  But a painstaking application of acetone with a bevy of small brushes, files, probes etc got it all off.
I was gonna fully polish the reservoir cover, but I kind of like the dual texture I have here -- the top is a partially smoothed out etching done with a wire wheel.
And the forklegs - omg what a pain.  I got off the factory chrome and the paint the p.o. badly applied over it.  But the casting is really rough, so I'm not sure if I'll leave it this way or paint it --
Offline scunny
  • don't call me expert
Re: Polishing is a Filthy and Thankless Task
« Reply #1 on: April 06, 2012, 11:06:45 PM »
been there, done that. think of it as a right of passage, much like the cleaning of carbs.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline Johnie
« Reply #2 on: April 07, 2012, 06:14:38 AM »
I have said it many times polishing is a tedious and dirty task, but the end result is always worth it. Have you considered just taking those forks to the next polishing level. I take it they are aluminum, but not sure how bad the casting is as you mentioned. I start with red rouge, then green and end with white. Here are a couple pics of my latest polishing on my K3 project.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline lucky
« Reply #3 on: April 07, 2012, 07:46:47 PM »
Well worthwhile it looks like to me.
Offline Damage Inc
« Reply #4 on: April 08, 2012, 12:02:25 AM »
Wow! Johnie. Those are some inspiring pics. Do you have any pre polish pics.
There is nothing Man makes, that Man can't break.
Markcb750
« Reply #5 on: April 08, 2012, 04:29:46 AM »
Filthy yes.  I do not find it thankless though.  even though I must provide my own.. ::)
Just like painting prep;  Lots of time with sandpaper, then just a little time with red then white rouge and a couple coats of wax.
« Reply #6 on: April 08, 2012, 05:04:09 AM »
Are those New O.E.spokes?  Sweet.
Offline Johnie
« Reply #7 on: April 08, 2012, 08:43:13 AM »
damageinc....as requested here is a pre-polish pic. A bit of a difference... ;D
« Last Edit: April 08, 2012, 12:08:05 PM by Johnie »
Oshkosh, WI  USA
Offline henrikm
« Reply #8 on: April 08, 2012, 09:34:31 AM »
Inspirational! Thank you.
How do you get to the point where you start polishing? Clean/degrease, 320, 600, 800 grit paper? Wet/dry? Machine/hand?
Offline brandEn
« Reply #9 on: April 08, 2012, 09:56:43 AM »
+1
Offline piute
  • Piute
  • TRICK OR TREAT...B....es
« Reply #10 on: April 08, 2012, 10:00:33 AM »
  Chrome / Polishing wont get ya home but can get ya laid THEY SAY
                         ....................... BUT BLACK IS BACK..................................
Ride to live Live for Jesus
1977 750 F2
Offline Johnie
« Reply #11 on: April 08, 2012, 10:28:03 AM »
To be honest, I have not yet used any sandpaper. I start by removing the clear with stripper. Then have at it with red, green and white rouge. Have been able to take out some nasty scratches too. However, I am not after concourse finish but am mighty happy with what I get in return. Keep in mind you have to use an agressive buffer. You need one that will not slow down when you are using it. Must be able to keep the RPM's going to heat that aluminum and fill some of the imperfections.
Oshkosh, WI  USA
Offline tweakin
  • tear down
« Reply #12 on: April 08, 2012, 03:44:04 PM »
Wow Andy.  Great results.  I have always had to sand first to get anything close to that.  I guess thats what I get fro using a HF wheel.  The pieces I started with were also in way worse shape than the ones you posted above.
