Author Topic: Strange clutch action - 1974 CB550  (Read 1512 times)
Offline puppytrax
« on: June 06, 2006, 11:54:08 AM »
I don't know what it is about these old Hondas...As soon as someone finds out you have one, they ask "You want another???"...   ::)
Last night I became the reluctant owner of a 1974 CB550 w/engine & frame & back wheel and not much else...The clutch cable was jammed in the out-of-engagement position, motor wouldn't turn over,  it looks like the arm on the case had been forced too far...while getting the cable off, I managed to get it one "notch" further...now it's in a peculiar position relative to where it should be...if you can imagine 9:00 o'clock as being the correct position, it's at 6:00 o'clock now...
It seems almost like a ratcheting mechanism, not that it's supposed to be, but it only rotates one direction...and the case is in the way now...so I can't force it to the correct position...
I'm sure I'll have to remove that case [right side, where kicker is] and re-position the arm...
Just curious if anyone else has had this happen...
BTW: The motor turns over very nicely now...   ;D  I pulled the entire engine out of the frame...
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline dusterdude
Re: Strange clutch action - 1974 CB550
« Reply #1 on: June 06, 2006, 01:21:07 PM »
damn,i wish someone would ask me if i "want another". :(
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« Reply #2 on: June 06, 2006, 04:08:31 PM »
Me too.
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
Offline puppytrax
« Reply #3 on: June 06, 2006, 04:28:12 PM »
You chaps are frequenting the wrong pubs...   ;)
