Author Topic: Air assist forks on a 650  (Read 1015 times)
Offline wardenerd
  • '77 550F '81 650C
« on: April 09, 2012, 05:06:22 AM »
I checked the air pressure on my forks and they were at ZERO Lbs.  I had not checked it in a year so is this normal to have some leakage?.  The air assist improves the handling 100% and the pressure appears stable.
Re: Air assist forks on a 650
« Reply #1 on: April 09, 2012, 05:09:09 AM »
Yeah mate, most air assisted forks only ran around 6-10 PSI, so your fork seals only have to be a little bit worn and you'll lose all your air. They are good though, aren't they? Cheers, Terry. ;D
Offline Mainerider
  • '04 VFR 800, '96 VFR750, 2001 SV650
« Reply #2 on: April 09, 2012, 07:24:03 AM »
If you don't want to deal with the air leakage you could always install a spacer (perhaps 3/4 inches tall) on top of each  fork spring to increase preload. Same effect as the air assist and easy to do.
Offline lone*X
« Reply #3 on: April 09, 2012, 07:44:51 AM »
Actually air does compress.  Spacers don't.  There is a bit of progressive stiffening with air, where spacers give you an always stiff spring rate.   Spacers are an option if you need to stiffen up sagging springs, but air assist does provide improved shock action over just spacers.   It does require well maintained seals.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline Doggie
  • CB550F, CB650c, CB550k, Cb750K
« Reply #4 on: April 09, 2012, 09:29:29 AM »
Can the 650 forks be swapped onto a 550?
        Doug
