Author Topic: 71CB500: Brake Pad Recommendations?  (Read 1229 times)
Offline Sjohnsone
« on: April 09, 2012, 02:22:20 PM »
Looking to replace my aging front pads that howl like a banshee.  Does anyone have a recommendation on a specific brand they found worked best?
Re: 71CB500: Brake Pad Recommendations?
« Reply #1 on: April 09, 2012, 02:30:52 PM »
Honda pads.
They seem to work the best with the stock rotor steel composition.
The skreech is from another cause than the pad choice.  Dragging/ maladjustment, incorrect assembly, pitted piston, master cylinder issues, brake line deterioration, etc.
Offline Sjohnsone
« Reply #2 on: April 09, 2012, 02:40:20 PM »
Thanks Twotired,
I thought it was just build up on the rotor, so I took some steel wool to it and used some brakeleen. There was a large amount of pad dust built up. It cleared up the screeching for about two days and then it was back.  There does seem to be a bit more drag than the manual recommends. Up on the centerstand when I spin it it doesn't slowly stop spinning, it rather abruptly ends after about 3-4 rotations.
« Reply #3 on: April 09, 2012, 06:03:08 PM »
When was the last brake system overhaul?  Who did it?  There are some quirky things about this vintage that are different from others.
« Reply #4 on: April 09, 2012, 06:10:21 PM »
I bought some Ferodos from vinbrake.com. They stop well and they do squeak a bit less. Your brake system should be gone over from end to end anyway no matter what pads you use.
Offline Sjohnsone
« Reply #5 on: April 10, 2012, 10:20:22 AM »
Twotired,
I couldn't tell you.  I bought it and the brakes were slightly spongy.  I inspected the pads and they were in good shape and within parameters to the Clymer.  I bled them and refilled....sooo...I'm picking up what you're putting down here...riding around on a mystery seems like a bad idea in general.
« Reply #6 on: April 10, 2012, 04:37:03 PM »
It would be a good idea to refresh your brake system. I rebuilt the MC myself from parts I bought from Honda. Gave the caliper to friend of mine who sent it to his rebuilder SS piston, it was cheap at his price.
One thing that did make a real difference was replacing the old rubber brake line with a Stainless braided line. All of that together gives me a very firm and responsive handle. Each thing seems to have made an incremental improvement.
