Author Topic: how easily should my motor turn over?  (Read 1913 times)
Offline 75 super sport
« on: April 10, 2012, 05:21:11 PM »
I just put my cylinder back on and i am turning my motor over via vise-grips at the points bolt and it feels like it takes a little more to turn it over then previous to taking it apart. I did not do a rebuild i just inspected and cleaned the top end because everything looked like new. The piston action is smooth, and no scrapes to the bores. Am I just over-reacting? Thanks in advance for the advice.
"Smoke em if ya got em"
Offline Gordon
  • 750K1, 550K2
Re: how easily should my motor turn over?
« Reply #1 on: April 10, 2012, 05:40:50 PM »
Were you turning it with the spark plugs removed before, versus turning it with them installed now?
Regardless.  Don't put too much torque on that advancer bolt.  You'll snap it right off.
« Reply #2 on: April 10, 2012, 06:31:33 PM »
No, spark plugs were removed in both situations. So obviously since your not supposed to put too much torque on the advancer nut, is it supposed to turn over with little to no force at the advancer nut? I dont really have to wrench on it but have to use a little force. I used 3" pipe clamps as a ring compressor. Is it possible that those may have bent the cylinder sleeves a little? :(
« Reply #3 on: April 10, 2012, 06:43:24 PM »
Not likely you bent a sleeve, they're pretty tough.
That nut is designed to turn the engine over but you should use a proper wrench and do it square on. With a 10 inch Crescent it should turn but its a firm presssure and never as easy as you'ld like it to be.
Whether you've broken a ring or such, there's the rub.
« Reply #4 on: April 10, 2012, 06:48:38 PM »
Almost positive that i didnt break a ring, piston action is smooth with noise or signs of a rub. You say there is a firm pressure, so there is supposed to be some resistance? I honestly think I could just be acting overly cautious, this is my first cb engine r&r and I am pretty much just learning as I go, from the hondaman manual of course.
Offline luap
  • LAWL
« Reply #5 on: April 10, 2012, 06:59:19 PM »
when you cleaned everything did you oil the jugs?
try putting on the kicker an see if it feels the same as it did before
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
« Reply #6 on: April 10, 2012, 07:07:27 PM »
There is definitely resistance. That's why its said to remove the plugs. With them in, its too hard to turn, though it will. With the plugs out its easier. But its always been too hard for me to feel comfortable doing it. Though I do obviously.
« Reply #7 on: April 10, 2012, 07:15:32 PM »
Yes, I did oil the jugs. I am probably just being overly cautious. I will have the motor back in tomorrow hopefully and I will give the kicker a shot. Thanks for the advice guys it really helps
