Author Topic: curious pod mod....  (Read 1564 times)
Offline ianfotheringham
curious pod mod....
« on: April 11, 2012, 09:45:32 AM »
So i dont have a factory airbox for my 750k4...had to go with pods...and am well aware of the downsides primarily revolving around the lack of resistance leading to the requisite main jet upsizing....
heres a thought im trying out currently - spraying the filters on each pod with a few thin layers of silicone spray sealant....
i figure if it does any harm i could just spray a little acetone over them and blow them clear...
anyone else tried this? thoughts?
Offline cmonSTART
Re: curious pod mod....
« Reply #1 on: April 11, 2012, 10:27:06 AM »
I would think for the amount of trouble you're going to go through to make that work, let alone keep each carb balanced, it's probably worth the $ to pick up a stock airbox from fleaBay.
I guess you don't really have much to lose.  Just my .02
1981 GL1100 Interstate
1978 CB750F Project
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #2 on: April 11, 2012, 10:37:07 AM »
Sounds like a buy an airbox off of FeEbay kind of idea.
Offline lone*X
« Reply #3 on: April 11, 2012, 10:56:46 AM »
Someone here recently posted that they had just wrapped duck tape around the bottom half of the pods to restrict flow for better drive ability as a temporary fix.  I think it was in the Projects section.  That would be the simple fix and if you find you needed more or less restriction, a simple unwrap and re-wrap with new tape would be easy.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline KJ790
« Reply #4 on: April 11, 2012, 11:56:23 AM »
Why not use a little air filter oil on them?
Offline lone*X
« Reply #5 on: April 11, 2012, 12:34:44 PM »
I have K&N's in my Jeeps (2), truck, and on my VTX and oil them as per instructions.  The oil does not restrict air flow.  If it did it would really screw with your mixtures.  K&N's reputation would go to pot to say the least.
Lone*X  ( Don )
75 CB550K1
Offline KJ790
« Reply #6 on: April 11, 2012, 01:01:47 PM »
I didn't mean K&N's watery "oil", I mean actual air filter oil that has solvents in it that evaporate after the oil is applied, causing the oil to get thick and sticky. This is meant for foam and gause filters typically, and is easy to clean out with mineral spirits or kerosene.
Offline lone*X
« Reply #7 on: April 11, 2012, 01:20:32 PM »
Sounds like pre-60's oil bath breathers.  Messy, and to do it to pods would drip all over your hot engine.  The tape is clean.  But it was only a suggestion.  Let the OP decide what he wants to try.  Nothing is going to fix pods, just help drive ability a bit.
Lone*X  ( Don )
75 CB550K1
Offline jamesb
« Reply #8 on: April 11, 2012, 01:25:24 PM »
i've used a high dense foam(packing foam) stuffed inside the pods with very good results.
Offline bikerbart
« Reply #9 on: April 12, 2012, 10:51:48 AM »
I have tried many different things on pods,but the one that worked well but was ugly as hell(unless its a rat bike)was 7 ounce alluminum cans with holes punctured in the bottoms,laugh but after all the trial and error,they worked.
Offline cmonSTART
« Reply #10 on: April 12, 2012, 12:55:44 PM »
I "fixed" my wife's old Kawi LTD like that.  It worked!
1978 CB750F Project
Offline LesterPiglet
  • 1977 CB550F2
« Reply #11 on: April 12, 2012, 01:44:02 PM »
I used them filled with steel wool as silencers on my Kwak triple while I got the silencers welded.  ;D
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #12 on: April 12, 2012, 01:44:28 PM »
i read a post somewhere where a guy had cut a section of plastic soda bottle to line the inside of the pod in a spiral pattern.........seems that there were pics of this as well.  it was sposed to be a real fix for pods.
MATT
