Author Topic: CB750 K0-K2 fork lowers with F3 fork tubes and dampers?  (Read 2218 times)
Offline brandEn
« on: April 11, 2012, 07:47:46 PM »
I am rebuilding my K4 forks. The fork tubes are not usable but the lowers are just fine. I have a complete set of forks from my 78 F3 rebuild. Has anyone installed the early K model fork lowers with the late model F2-F3 fork tubes and fork internals? The tube and dampers are quite a bit different.
« Last Edit: April 11, 2012, 07:56:54 PM by brandEn »
Offline brandEn
Re: CB750 K0-K2 fork lowers with F3 fork tubes and dampers?
« Reply #1 on: April 11, 2012, 07:59:42 PM »
So I was just looking at my Hondaman book and discovered my forks are K2 or earlier forks. They have the early style dampers... So can I run F3 tubes and internals with the K2 K1 K0 fork lowers?
I have these type forks CB750
« Last Edit: April 11, 2012, 08:09:34 PM by brandEn »
Offline brandEn
« Reply #2 on: April 11, 2012, 08:11:07 PM »
These are the 1978 CB750 F3 forks. I want to put the fork tubes and fork internals in the K2 lowers. Yay or nay?
« Reply #3 on: April 12, 2012, 03:13:27 AM »
G'Day Branden, sorry mate, when you PM'd me I took it that you were using K4 lowers. Nope, you can't use F2/F3 tubes in K0-K2 forks, unless you can somehow manage to machine the lower portion of each tube to accept the external bush that was common on the K0-K2.
Just buy some K3-K6 sliders (or better still, F0-F1 or K7/K8 sliders, they're taller and you can install a fork brace) and use your F2/F3 tubes. Don't forget you'll need a K3 or later caliper mount and fender to go with the later model forks. Cheers, Terry. ;D
Offline brandEn
« Reply #4 on: April 12, 2012, 03:14:25 AM »
Thanks!
« Reply #5 on: April 12, 2012, 03:25:44 AM »
No worries mate, have fun! Cheers, Terry. ;D
