Author Topic: Bike suddenly stopped at a light and won't start.  (Read 1555 times)
Offline flateric
« on: April 14, 2012, 11:26:48 AM »
Today, I went for a little test ride after a long winter of "restoring" my CB550K (1977). It ran fine for 15min in town then at a light it just stopped. It seems like an electrical problem to me but I don't know where to start looking.
The bike always started right away at first kick but this time it did not do anything. It is like loosing every sort of spark, electrical connection... The battery is fine, there are no more dash light going on when I turn the key and even when I try to push start it, it just does little "put put put" but not even sign of life...
Could someone tell me where to start?
Thank you
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: Bike suddenly stopped at a light and won't start.
« Reply #1 on: April 14, 2012, 11:29:35 AM »
Fuses.
Offline flateric
« Reply #2 on: April 14, 2012, 11:36:15 AM »
That's a good start... I am going to check that first.
Thanks
Offline Spanner 1
« Reply #3 on: April 14, 2012, 11:43:07 AM »
+1.... main fuse... you are carrying spare fuses, right ?... replace the main fuse, ride home and then service the 3 fuseholders right away. Very common for bikes to suddenly stop because the fuse/ fuse holder heats up and melts the fuse...... fix it now before it happens again IMO  ;)
BTW... Main =15A
Headlight = 7A
Taillight = 5A
« Last Edit: April 14, 2012, 11:45:16 AM by Spanner 1 »
Offline dhall57
« Reply #4 on: April 14, 2012, 11:47:33 AM »
Sounds like something similar that happened to my 750K6. Check your ignition key cylinder and make sure where wires are soldered to back of it have not broke loose.
« Last Edit: April 14, 2012, 11:50:15 AM by dhall57 »
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline flateric
« Reply #5 on: April 14, 2012, 11:54:06 AM »
Thanks.
I actually ended up pushing the bike home (it was mostly downhill... lucky). I will check the fuses and the fuse box in a bit. I do not have internet on the go... :-)
Offline flateric
« Reply #6 on: April 14, 2012, 12:13:39 PM »
Nice one... It was the main fuse. I changed it and the bike started right away again... Thanks for your help. I now have a box of spare fuse in case...
I have checked the fuse holder and it looks clean and nice.
Offline jamesb
« Reply #7 on: April 14, 2012, 12:34:56 PM »
check your wiring you may have a exposed wire grounding out some where mine was doing it and it was the break light. it had a bare spot and was grounding out on the frame.every time i hit the break it would die and not start it was blowing the main fuse.
Offline Grabcon
« Reply #8 on: April 14, 2012, 03:56:55 PM »
My kids 1978 CB550 had similar issues. It turned out to be the standard fuses just were not tight in the fuse block. Changed it out yo the new style flat fuses. No issues since.
CB750   1974 - Gone
CB750F 1976 - Gone :(
CB550   1978 - Gone & now back
CB900F 1981 - Gone
ST1100 1991 - Gone
ST1100 2000 - Gone
VFR800 2008 - Gone
ST1300 2008 - Gone
BMW F700GS - Wife's
VFR1200X 2016 - Mine
Offline Spanner 1
« Reply #9 on: April 14, 2012, 05:30:56 PM »
OP.... 'looks clean and nice' is obviously not clean and nice enough  ;) or the fuse would not have melted  : :o... need to shine-up the fuse clips and squeeze the clips together carefully so as the fuse is gripped tightly by the clips. If any doubt about the tightness, then change the 3 fuses out for auto. type 'blade' fuses/holders ( about 3 bucks ea. @ Advance Auto ). Get the ones with the 30A rated 'yellow' pigtails and put the relevant size fuse in.... good luck  :)
Offline flateric
« Reply #10 on: April 15, 2012, 12:07:03 AM »
Thanks for the heads up. Next time it blows, I will change everything for 'blade' type fuses/holder.
I will also check for ground issue along the wiring harness.
