Author Topic: Where can I find a 530 16-tooth front sprocket?  (Read 3324 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: April 17, 2012, 10:31:46 AM »
I think JT Sprockets makes one but I can't seem to find one anywhere. Anybody know where I can source these from?
Offline lucky
Re: Where can I find a 530 16-tooth front sprocket?
« Reply #1 on: April 17, 2012, 10:49:12 AM »
Go to http://www.yamatoyamotorsports.com/
Call if you need to, and they can get you all set up for front and rear sprockets for your Honda CB750.
Offline RFogelsong
-Rob
Hondas past/present:
SOHC1:'74 CB125, '78 XL125
DOHC2:'71 CB450K
SOHC4:'73 350F, '75 400F, '75 550K
DOHC4:'81 900F, '01 1100XX
V4:'85 VF1000R, '86 VF500F, '08 VFR800
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #3 on: April 17, 2012, 01:14:28 PM »
None of those from Z1 are correct. Yamatoya doesn't have one listed but I'll call anyway. Anyone else?
Offline RFogelsong
« Reply #4 on: April 17, 2012, 01:32:52 PM »
What bike is this for?  Those fit my 550k1
-Rob
DOHC2:'71 CB450K
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #5 on: April 17, 2012, 01:34:50 PM »
My 750.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #6 on: April 19, 2012, 10:45:22 AM »
Bump.. anyone?
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #7 on: April 19, 2012, 11:46:47 AM »
http://www.jtsprockets.com/catalogue/sprocket/JTF288-16
Here is what I found. JTF288 is the fitment and .16 is the number of teeth. The 16 is a little hard to find why not go for a 17T?
« Last Edit: April 19, 2012, 11:54:31 AM by Duanob »
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline lucky
« Reply #8 on: April 19, 2012, 12:25:17 PM »
You are not going to get a 16T sprocket.
The 1978 CB750's had the internal 4th and 5th transmission ratios were higher.
You can get 15T,17T,19T   ....starting to see a pattern? IT is because of the number of teeth on the rear sprocket.
Cycle-X sells a 19 tooth. It sure must be close to touching the engine case all the time. You would have to watch the adjustment of the chain like a hawk.
« Last Edit: April 19, 2012, 12:42:45 PM by lucky »
Offline lucky
« Reply #9 on: April 19, 2012, 12:26:38 PM »
17 would be very low. Stunt bike low?
« Last Edit: April 19, 2012, 12:43:40 PM by lucky »
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #10 on: April 19, 2012, 12:50:42 PM »
Running a 10mm offset rear sprocket from CycleX that only comes in 46-teeth, so 17/46 (2.71) was the closest ratio I could get to the stock 15/41 (2.73)
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #11 on: April 19, 2012, 02:57:41 PM »
Sounds like a 17T would be the ticket over a 16? 16/46 = 2.875 might be a little boggier compared to stock (2.73)
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #12 on: April 20, 2012, 09:33:28 AM »
Oh.. do I have it backwards? I want less boggy! :) So 19?
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #13 on: April 20, 2012, 09:58:09 AM »
oops sorry! I might be confused here, math isn't my strong suit  :o . I had to redo the ratio difference on my bike again and found my mistake. The smaller the ratio number the boggier your performance. But I would think you would want to stay as close to stock ratio number that you can since the Honda engineers designed the bike that way.
Here is what I did:
Went from stock 17T front, 37T rear (2.176)
to: 17T front 36T rear (2.118) It's not much of a change but I notice about a 400 rpm drop or a 4MPH rise at Hiway speeds roughly 6000 rpms. Any more and I am sure I would notice a more sluggish take off around town. going too much the other way and at hiway speeds you will always be searching for that higher non-existant gear. And your mileage will drop.
« Last Edit: April 20, 2012, 10:00:30 AM by Duanob »
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
« Reply #14 on: April 20, 2012, 10:18:57 AM »
Smaller front and/or larger rear = quicker acceleration. I'd be careful going with anything smaller than the 17 front that was stock on the early F's. Chain bind can = chain break. "Cases-in-point" would be the early 750's that snapped chains and tore the #$%* outta expensive cases. They changed the sprockets after all those expensive warranty claims. Generally 1 tooth on the front = 3 on the back so going down 1 on the front is approx = to going up 3 on the back as far as acceleration. Your back is DOWN 2 to 46 so that's better for less rpm at highway speeds or it's about like a 17 and 2/3 tooth front sprocket. I see why you'd like to find a 16 to offset that but I'd be careful with a 16!
Offline Roach Carver
« Reply #15 on: April 20, 2012, 10:31:04 AM »
The 69s came with a 16 tooth sprocket I bet they are still out there. Smaller front or larger rear wil have less top speed but more bottom end.
