Author Topic: anyone use a battery tender on there cb?  (Read 7788 times)
Offline dergs713
« on: April 18, 2012, 07:06:04 PM »
Brand new battery tender, and a newer battery that been off the bike for 6 months now.  I hooked it up and came back out in 3hrs to check on it, and its was making a sizzling bubble noise.  Took it off due to feeling like this is not correct.  12v battery tender, and 12 v batt.  where did I go wrong..? Is my batt trashed now.  I dont get it.
Any help would be greatly appreciated. Thanks
Matt
Offline Killer Canary
  • Typical Bran Muffin
Re: anyone use a battery tender on there cb?
« Reply #1 on: April 18, 2012, 07:07:39 PM »
Incorrect polarity?
Kawi GPz900, H1
Offline Elan
    • Vital Motor Parts
« Reply #2 on: April 18, 2012, 07:08:44 PM »
it should be a low amp battery charger. like 1.5 amps or something like that. Regular 12v car ones have too many amps
76 750k
Offline mrrch
« Reply #3 on: April 18, 2012, 07:08:54 PM »
Was the charger or battery sizzling?
my build
Offline dergs713
« Reply #4 on: April 18, 2012, 07:11:25 PM »
Charger hot and battery sizzling.  Pretty pissed I have not even 30 min on that battery, lucky I got the Tender for little to nothing.  So i take it im sol huh...?  and I shouldnt use the tender.  I didnt know there were motorcycle ones..
Matt
Offline Elan
    • Vital Motor Parts
« Reply #5 on: April 18, 2012, 07:17:10 PM »
Matt
I wouldn't assume the battery is junk. I'd get a low amp charger and try again. Walmart has them cheap.
76 750k
Offline dergs713
« Reply #6 on: April 18, 2012, 07:20:07 PM »
Damn, thought I was being slick..lol  Could I check my levels on the batt and throw some distilled water in there to save it, or is it not even worth it?
Matt
Offline Gordon
  • 750K1, 550K2
« Reply #7 on: April 18, 2012, 07:23:05 PM »
As long as you didn't boil any of the cells in the battery dry, you should be fine.
Offline Elan
    • Vital Motor Parts
« Reply #8 on: April 18, 2012, 07:27:04 PM »
Matt
I'm a sealed agm man myself, but typically you can ad distilled water. Start at the lower level because it will rise.
76 750k
Offline Prospect
« Reply #9 on: April 18, 2012, 07:39:17 PM »
Battery tender Jr. is what I have been using for the last 5 years.  The battery is always connected to it even in winter.  Their $20 on ebay and their excellent with a good warranty. They will extend the life of a battery another year or so.  Your bike will always have a good and fully charged battery for better starts etc.  I love it.
http://www.ebay.ca/itm/DELTRAN-Battery-Tender-JUNIOR-12V-Motorcycle-Car-Charger-Maintainer-NEW-JR-RV-/290699213503?pt=Other_Vehicle_Parts&hash=item43af05fabf
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline Hablo
« Reply #10 on: April 18, 2012, 07:44:35 PM »
^^I use the same Deltran tender as above.  Have had no problems with it but yes, even with that Deltran
the water in my battery will bubble while charging.
'73 CB350F
Offline jamesb
« Reply #11 on: April 18, 2012, 07:51:26 PM »
I've had good luck with my schauer battery charger i leave it on all winter it will charge the battery and load it like it is being used and recharge it again 19.95 walmart.let yours set for a day then put a little distilled water in yours like others suggested.you should be alright.when i did auto electric it happened all the time.very rare did it mess up a battery.
« Reply #12 on: April 18, 2012, 07:54:53 PM »
Telling us you have a battery tender is like telling us you have a motorcycle.  There are lots of different types, brands, and designs.  But, if it was cheap, you may have just bought a name descriptor rather than a quality tool.
"There is hardly anything in the world that some man cannot make a little worse and sell a little cheaper, and the people who consider price only are this man's lawful prey."
"It's unwise to pay too much, but it's worse to pay too little. When you pay too much, you lose a little money — that is all. When you pay too little, you sometimes lose everything, because the thing you bought was incapable of doing the thing it was bought to do. The common law of business balance prohibits paying a little and getting a lot — it can't be done. If you deal with the lowest bidder, it is well to add something for the risk you run, and if you do that you will have enough to pay for something better."
Quotes above are usually attributed to John Ruskin
« Reply #13 on: April 19, 2012, 03:03:23 AM »
I got mine at TSC, they have a sale every so often. One of the smart ones for $20. Money well spent, it kept the battery happy all winter, I use it to charge my diesel Kubota with dead rectifier and overall works great.
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #14 on: April 19, 2012, 05:16:08 AM »
6 months is too long to have been out of service & not recharged. A conventional lead/acid battery, fully charged can sit on a shelf for maybe up to 3 months before it requires recharging. By 6 months, sulphation (sulfation) would have occured. Crystals form on the plates and form an insulator if you like & reduce the chance of charging the battery at all. Some chargers have multi stage programs which will attempt to break down the sulphation, however they cost a lot more than a regular charger/tender.
Get a new battery & keep it healthy all year long, don't let it sit there & self discharge.
« Last Edit: April 19, 2012, 05:29:19 AM by Frostyboy »
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline Lostboy Steve
« Reply #15 on: April 19, 2012, 05:18:21 AM »
My brand new battery gurgles when you get it hot. (From trying to start a bike that wasn't getting fuel for too long.) I keep it on a tender and its fine.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #16 on: April 19, 2012, 05:46:54 AM »
Yeah, mine always do that. If its a "Battery Tender" brand battery tender, its my understanding that they have circuitry in them to keep them from overcharging a battery. You can hook them up and leave them all winter. Untended. AS said, be sure its topped off, not overfilled, and should be fine IMO.
Offline Johnie
« Reply #17 on: April 19, 2012, 05:52:10 AM »
I had a miracle happen. My Goldwing had a Westco battery which I left on the Battery Tender every winter. In summer when I was riding the 750's a lot I put it on the Tender too. That Westco battery was going on 9 years and I decided to change it out just so I would not get stranded. I could not see pushing my luck further than the time this battery had already given me. If you can keep them from sulfating you will get good life out of a good battery.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline EricHa
« Reply #18 on: April 19, 2012, 06:06:53 AM »
I use a Battery Tender Jr. as well. I just hook it to each of my bikes for 24 hours or so, once per month in the winter. Keeps 'em all ready to go. I have heard of concerns about leaving a tender on a bike constantly, in regards to lightning or power spikes. A surge protector may be of some help there. Unhooking the battery cable from the bike in the winter would probably be the safest option.
1975 Honda CB550K1
1976 Honda CB750K6
1977 Kawasaki KZ900A5
Offline lucky
« Reply #19 on: April 19, 2012, 06:47:22 AM »
Matt
Yep.....There are motorcycle trickle chargers.
« Reply #20 on: April 19, 2012, 07:27:30 AM »
Best practice by far.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #21 on: April 19, 2012, 03:10:53 PM »
From my experiences in frying my new Yuasa battery that wasn't even a year old, go with a smart tender. One that fully charges the battery then automatically goes into trickle mode. I had a 1 amp motorcycle battery charger I left on all winter and it pretty much boiled the fluid right out of the battery. I refilled and recharged it but it lasted a couple of days before it died again. it was toast. My wife got me a $150 gift card to the local cycle shop so a nice smart tender and some gortex riding gloves are on my list.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
bollingball
« Reply #22 on: April 19, 2012, 04:29:21 PM »
Matt
Sorry about your trouble. Live and learn. Here is a good place to start learning. Lots of other things to read about on this site about battries.
http://www.batterystuff.com/kb/articles/charging-articles/how-do-i-pick-a-battery-charger.html
Ken
bollingball
« Reply #23 on: April 19, 2012, 04:45:12 PM »
Here is another one.
http://batterytender.com/resources/battery-basics.htm
TT told me about this charger when I was in the market for one. I have been happy with it. I do think I go a little overboard I now have 5 chargers some big ones for different battries. My wife has to slow me down every once in a while ;D
https://www.denniskirk.com/yuasa/6-12-v-1-5-a-battery-charger.p282952.prd/282952.sku
Ken
Offline Bailgang
  • Scott
  • Indiana
« Reply #24 on: April 19, 2012, 07:19:09 PM »
Same here plus I'll hook it up while I'm working on something else on the bike.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
