Author Topic: New cam for my 76 CB750F  (Read 2423 times)
Offline Gustlock
    • Gustlock Aviation Photography
« on: April 19, 2012, 07:45:10 AM »
The cam in my 76 CB750F is worn and needs replacement.
If I am correct I understood that all CB750 SOHC cams will fit on the bike but not all will run smooth.
What cams can I use for my bike? Currently I have two possible replacements: K7 and F2.
It's a stock engine CB750E-2531459.
Thanks!
1976 CB750F Café Racer project
Re: New cam for my 76 CB750F
« Reply #1 on: April 19, 2012, 07:59:35 AM »
You need to know more than I know about this, but I wanted to get subscribed. I would be suspicious that the 77/78 cams are what you would not want to use.
Your 76 is more like 76 and earlier bikes, and i would think all those cams would work and run fine.
Changes in the later bikes, esp in the F2 were greater.  Maybe the 77/78Ks are still OK/compatible.
Hinomaru
« Reply #2 on: April 19, 2012, 08:46:56 AM »
The K7 cam will work in your F1 engine as it’s the closest match. To break down 750 compatible cams, the part numbers provide a strong clue:
14101-300-020: K0 to K6
14101-392-000:  F0 / F1 and K7 / K8
14101-410-000: F2 / F3
See this recent thread that’s related to your question:
http://forums.sohc4.net/index.php?topic=105053.0
« Reply #3 on: April 19, 2012, 09:07:43 AM »
Interesting.
« Reply #4 on: April 19, 2012, 02:51:42 PM »
The K7 and K8 is supposed to be identical to the F/F1 cam except the manual has it listed as being timed 5o differently 40o vs 35o. I think I'd try the F2/F3 myself but have not attempted.
« Reply #5 on: April 19, 2012, 04:02:17 PM »
I would take an F2 cam off someones hands, they come highly recommended for mild performance use.
Offline Gustlock
« Reply #6 on: April 20, 2012, 02:22:17 AM »
Thank you all for the replies! Still not really sure what cam to go for... I think I stick with the cam that looks best/minimum ware.
