The SOHC/4 World Tour is in under way.
That swingarm is made by " CAL-FAB " of California, which is no longer in buisness. A stock Suzuki arm has extra bracing across the backside of the box section. Also it has a large " X " on top of the box section. Better yet, i found a pic of a GS 1100 arm.........
I think it is one of the "stolen" JMC swingarms.
As far as I know the GS swingarms use a bigger diameter on thr pivot bolt, so you have to sleeve down, or accurately drill your frame..
Quote from: 754 on April 22, 2012, 08:48:07 AM As far as I know the GS swingarms use a bigger diameter on thr pivot bolt, so you have to sleeve down, or accurately drill your frame.. The GS swingarms use the same size pivot through bolt as the 1973-1980 KZ900-KZ1000's which is 20mm. Note; That is the diameter of the bolt ( 20mm ) as for length..... I don't have a clue. YOU LOOK IT UP !
Quote from: BLUE71TURBO on April 21, 2012, 09:35:51 AM That swingarm is made by " CAL-FAB " of California, which is no longer in buisness. A stock Suzuki arm has extra bracing across the backside of the box section. Also it has a large " X " on top of the box section. Better yet, i found a pic of a GS 1100 arm......... Some one know if there is a chain guard/guide for this swingarm? (i have the same on my bike)http://www.ebay.com/itm/GSXR-600-750-SWINGARM-CHAIN-GUIDE-/280867810481?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item416506acb1Bert
Nice detective work Jon... Thanks Frank and Rob.... Was it a direct bolt in Rob.?
Hey Rob,There is no clearance problem with the swingarm,here's some pictures that i have just take,Bert
