Author Topic: CB550 camshaft cover  (Read 1437 times)
Offline mazingerzeca
« on: June 05, 2012, 02:35:15 AM »
Hello all. Is this possible to disassemble the CB550 camshaft cover without removing the engine from the frame? I have an oil leak between that cover and the cylinder head.
Thank you.
Offline Bailgang
  • Scott
  • Indiana
Re: CB550 camshaft cover
« Reply #1 on: June 05, 2012, 02:50:35 AM »
Yes but if it still has the factory phillips head screws it may be a challenge breaking them loose but if you can manage to break all of them loose there is plenty of clearance to remove the cover with the engine still in the frame.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #2 on: June 05, 2012, 05:23:56 AM »
Do be careful on reassembly, there's a caution in the shop manual to prevent bending valves when refitting the cover.
Be sure to read this thread or others like it.
http://forums.sohc4.net/index.php?topic=82508.msg928683#msg928683
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline jamesb
« Reply #3 on: June 05, 2012, 05:41:19 AM »
definitely listen to frostboy i had just got one of my cb550s it was about 6yrs ago and thought it would be like the 350f it;s not.i bent vavles puttingit back on  got on here and found out your supossed to rubber band them to keep them held up is what i was told.
« Reply #4 on: June 05, 2012, 08:46:46 AM »
Thanks for the tip. I had reassembled this engine before. I didn't bend any valves, but I made the tachometer gear mistake. I installed it on the cover before fitting it over the cylinder head, and I smashed the gear a bit, but fortunatelly it still works. I had almost forgotten it.
Offline Fritz
« Reply #5 on: June 05, 2012, 02:49:09 PM »
Buy an impact driver with correct size bits and you will never again have any problems with those screws...
1976 CB550F
Offline Bailgang
  • Scott
  • Indiana
« Reply #6 on: June 05, 2012, 04:19:04 PM »
I was assuming the frame might get in the way of getting a straight shot with an impact driver on some of them but taking a quick look at mine and it doesn't seem like it would be a problem. I wouldn't know because I pitched the original rusted and chewed up screws away when I first took the engine apart and replaced them with SS allens.
Scott
71 cb350 twin
77 cb750 F2
