Author Topic: Camshaft custom grind question..lift & duration choices.  (Read 2652 times)
Offline grcamna2
« on: April 22, 2012, 12:44:30 PM »
I want to have a custom camshaft ground for my little CB350 twin.I'd like to keep it as close to stock specs as I can so I can keep 90% of the low-mid range power band as the Original Honda camshaft has.Megacycle sells a very mild cam..I don't know the specs of the O.E.camshaft but I do for the mild Megacycle camshaft.I'm considering going w/ a bit more duration but not really much more lift than Stock.
Has anyone here had a custom camshaft ground for mild street use..? I enjoy mid-range power but just don't want to sacrifice the great 7-9500rpm top end blast of the stock camshaft.
                                    Any Idea's ?
Offline grcamna2
Re: Camshaft custom grind question..lift & duration choices.
« Reply #1 on: April 23, 2012, 03:45:36 PM »
Bump
Offline grcamna2
« Reply #2 on: April 24, 2012, 08:36:53 PM »
I'll be running O.E. carbs./air filters and Exhaust..it'd be nice to have maybe 5% more than the Stock camshaft has.The Megacycle mild street camshaft is really more than I wanted..,it's about 1/2-3/4 Race grind. Who here has had a custom grind done in a similar manner ?
Offline trueblue
« Reply #3 on: April 24, 2012, 11:06:47 PM »
I can't provide much useful info but here is some good reading
http://www.popularhotrodding.com/tech/0607phr_camshaft_basics/viewall.html
1979 CB650Z
Offline Doctor_D
« Reply #4 on: April 24, 2012, 11:21:11 PM »
The webcam 41a is very, very mild.
Sent from my ADR6400L using Tapatalk 2
Take care,
David
1978 CX500
1971 Norton Commando
« Reply #5 on: April 25, 2012, 12:10:09 AM »
 The early 350 cams are hotter..
Offline grcamna2
« Reply #6 on: April 26, 2012, 08:35:23 PM »
I know those early CB350K cams are higher rpm topend cams but I like more midrange & I'm trying to figure out the best way to have my stock camshaft built up and then custom reground so I can have most of the power in midrange- 3/4+ rpm power band...,from about 4500-9750 rpm & still have it pulling strong at 9500 rpm.The stock cam that's in it will pull nice at all the right rpm's & I just want maybe 5-10% more of the mid-upper rpm's.
I also wondered if any of you have installed a very mild camshaft in a CB350K Twin such as a Megacycle # 123-00 which is they're mildest street camshaft and have used it w/ stock exhaust & carbs & filters.I asked on that Honda twins forum,but nobody ever answers me  :(
« Reply #7 on: April 26, 2012, 08:38:55 PM »
 Be easier to regrind your stock cam, I am thinking... IU had a.. I think Kenny Harmon cam in my 350.. actually 360cc.
. it would rev to about 13 or 14,000 RPM..
Offline grcamna2
« Reply #8 on: April 26, 2012, 08:51:43 PM »
I understand 754,
         I'd like to have my stock camshaft reground..but I'd rather not have it rev to 13-14K;just more mid-top end pull will work great...something very mild.I'm looking for a "close to stock" set of specs to give to the camshaft grinders as far as lift & duration #'s.  :)
