Author Topic: PD Carb Questions  (Read 6151 times)
Offline lucky
Re: PD Carb Questions
« Reply #25 on: April 26, 2012, 05:04:57 PM »
Thanks for reporting back right away.
Why not just increase the main and see if it fattens up the midrange too.
Maybe no needle shims?
Looking forward to another report. Very exciting.
Offline lucky
« Reply #26 on: April 26, 2012, 05:18:04 PM »
Oh...I forgot to ask, Did those brass washers fit down in that pocket in the bottom of the slide or did they sit over the top of it? Very important.
Offline brewsky
« Reply #27 on: April 26, 2012, 06:14:11 PM »
Lucky,
The reason not to go with a bigger main is it is already too rich at WOT.
As far as I remember, the shims did fit into the recess.
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline lucky
« Reply #28 on: April 27, 2012, 09:03:20 AM »
Lucky,
Thanks Brewsky for that info.
Ok ...I see what you meant about WOT issue.
So if you took off the shim and keep the #42 idle jet maybe that would be the way to fatten up the midrange?
Sure wish you knew about that washer fitting down in that pocket because that is a .012 difference. Well .012 from .019 is + .007 thousandths difference.
Let us know if you rework it . Thanks.
I know it is a lot of work.
Offline I Zombie
« Reply #29 on: April 27, 2012, 10:04:04 AM »
Lucky I got my keyster kits in the mail yesterday & yes they have adjustable clips. Kit # KH-1156
sorry no pics
78 CB750K
Offline lucky
« Reply #30 on: April 27, 2012, 12:03:31 PM »
sorry no pics
ONE clip with 5 grooves?
« Reply #31 on: April 27, 2012, 01:46:13 PM »
sorry no pics
Have you measured to see if the taper profile, overall length, and diameter of the needle is the same as what was removed from the carbs?
Offline I Zombie
« Reply #32 on: May 01, 2012, 09:35:43 AM »
Well I haven't done any exact measurements but from what I can see, they're the same length & taper. The nonadjustable 78 needles match the second from top needle groove on the 77. Haven't had much time to play with em yet but once I do I'll report back.
78 CB750K
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #33 on: May 02, 2012, 08:50:00 AM »
Made one of these to adjust the pilot screws as suggested here. Works great! $3.
Offline lucky
« Reply #34 on: May 02, 2012, 02:44:47 PM »
Very interesting information IZombie. Thanks
