Author Topic: Honducati  (Read 107756 times)
Offline Mtmooradian
Honducati....
« Reply #50 on: May 10, 2012, 05:13:53 PM »
I have tail lights!!
Re: Honducati....
« Reply #51 on: May 11, 2012, 02:21:53 AM »
Nice neat work mate, looking good! Cheers, Terry. ;D
Offline Mtmooradian
Honducati....
« Reply #52 on: May 15, 2012, 09:16:42 AM »
Ok..... How much oil do i need. The tank is either going in the swingarm, or under the seat.... Can I get by with 2 qts
Re: Honducati....
« Reply #53 on: May 15, 2012, 12:00:22 PM »
Nope, the standard tank holds around 3 litres mate, that's around 5 pints? Cheers, Terry. ;D
Offline luap
  • LAWL
Re: Honducati....
« Reply #54 on: May 15, 2012, 07:47:48 PM »
what mm forks does the 92 gpx 600r run? how much are the gpx triple tree then the stock 750, gonna be a cool bike
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline ozcaferacer
Re: Honducati....
« Reply #55 on: May 15, 2012, 07:49:34 PM »
Great work with some really innovative ideas!  :)
I'm really enjoying your thread.
Cheers.
Offline Mtmooradian
Honducati....
« Reply #56 on: May 15, 2012, 08:59:58 PM »
The forks are 37mm, the triples are wider and the stem swap was pretty simple. The stock cb750 stem is a larger diameter. I sleeved the inside of the stem and then brazed the insert in. After pressing the stem in and welding it's a perfect match.
Offline Mtmooradian
Honducati....
« Reply #57 on: May 16, 2012, 10:02:30 AM »
Thank you for all the kind words...
Offline Mtmooradian
Honducati....
« Reply #58 on: May 17, 2012, 01:15:27 PM »
 Swingarm oil tank.
I'm going to piggyback this off the bottom of my swingarm. Offset so the chain clears...... Drill holes in each leg and make a nice plate with a breather and cap
Re: Honducati....
« Reply #59 on: May 17, 2012, 02:47:55 PM »
Cool! That should work mate, well done! Cheers, Terry. ;D
Offline Mtmooradian
Honducati....
« Reply #60 on: May 17, 2012, 07:00:51 PM »
Checked the clearance and chain line. It's a go
Offline Roach Carver
Re: Honducati....
« Reply #61 on: May 17, 2012, 07:39:09 PM »
Markt
Offline Mtmooradian
Honducati....
« Reply #62 on: May 21, 2012, 08:43:00 PM »
 Swingarms ready
Offline lordmember1969
Re: Honducati.... W/swingarm tank
« Reply #63 on: May 21, 2012, 11:03:52 PM »
That should work :) You will get into some challenges when you are about to put on the oil lines. But it can be done:) I used pretty thick hydraulic hoses and they where a pain to work with.
Subscribed :) :) :)
1977 CB 750 SS Cafe
1977 CB 750 Basket case
1971 Mustang Grande
1928 Model A Pheathon Hot Rod
1977 Harley Custom FXE
http://forums.sohc4.net/index.php?topic=70333.0
Offline Mtmooradian
« Reply #64 on: May 22, 2012, 05:47:10 AM »
I own a hydraulic/fab shop so Lines should be pretty easy .I'm going to use a SS braided Teflon and am going to modify the the engine side ends to take JIC - 8
Offline Mtmooradian
« Reply #65 on: May 22, 2012, 08:07:20 AM »
I have two extra swingarms.... Any interest if I make a couple of these? Would come with oil lines.
« Reply #66 on: May 23, 2012, 12:44:30 AM »
Yep, I'm interested mate, I presume it'll come with a threaded cap and a breather pipe too? Cheers, Terry. ;D
Offline Mtmooradian
« Reply #67 on: May 23, 2012, 07:22:00 AM »
 as soon as a get this bike together and make sure the ports are in an ok area I'll make a couple of these. Yes It will have the threaded cap, an inlet and outlet port, port for a breather, and SS lines and adapters to hook to engine.
Offline Mtmooradian
« Reply #68 on: May 23, 2012, 07:16:58 PM »
 Getting ready to put the motor back in.....
« Reply #69 on: May 24, 2012, 12:13:24 AM »
Nice! Have you measured the capacity of your combined swingarm/oil tank? I'd love one with a larger capacity than the stock tank, if possible? Oh, and I'd want shock mounting points like yours, of course. Cheers, Terry. ;D
Offline Mtmooradian
« Reply #70 on: May 24, 2012, 06:41:47 PM »
Wiring harness is done and the motors back in.
« Reply #71 on: May 25, 2012, 12:13:03 AM »
Very nice! ;D
Offline Tews19
  • I am no
« Reply #72 on: May 25, 2012, 07:23:59 PM »
Got my attention. How long do you think before ETA on the road?
1970 Honda CB750 survivor.
Offline brandEn
« Reply #73 on: May 25, 2012, 10:01:27 PM »
Im REALLY diggin this build. Is the tank in final position? Looks like the ass end of the tank needs to come down about an inch or so from the pics...
Offline Mtmooradian
« Reply #74 on: May 25, 2012, 10:12:26 PM »
Tank isn't set yet.....
