Author Topic: CB550 pilot screw  (Read 760 times)
Offline mazingerzeca
CB550 pilot screw
« on: April 24, 2012, 02:48:43 pm »
Hello all.
I've just got running my fully rebuilt CB550. The bike is a K3, and the carburetors are the PD type, the later ones. I didn't adjust ignition, not carbs, just turned the key on, pushed the buttom and it started almost at the first try and sounded good. So, I begun to adjust things, and noticed that the pilot screw were totally loose, almost outside of the thread, so I screwed them inwards totally, and unscrewed them 1 and 1/2 turns off, according to the manual. The bike runs with the choke on, but it doesn't maintain idle, even screwing in fully the idle screw, so, my question is, what did I do when I screwed the pilot screws in, did I make the mixture richer or leaner? Should I leave the screws loose, as it was at the beginning?
Thank you.
Re: CB550 pilot screw
« Reply #1 on: April 24, 2012, 04:22:50 pm »
Stock air filter and exhaust?
The Pilot screws for PD carbs are "Idle Mixture Screws" turning in leans pilot mixture, turning out enriches idle mixture.
Stock settings only apply to bikes with stock components.
Loose screws tend to fall off motorcycles.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: April 24, 2012, 04:24:24 pm »
Hehehe
A lot ride them also.
