Author Topic: Drilling frame drain holes - cb750  (Read 2685 times)
Offline Prospect
« on: April 25, 2012, 05:56:42 PM »
Apparently some of the k1 frames didn't come with drain holes so I'm thinking of drilling my own.  The two holes are supposed to be ahead of the engine mounts near the dowtubes.  Any of you guys do this and can give me some pointers?  It's fairly straight forward but I don't want to drill in the wrong spot and have a lesser effect.  Also what's  a good product to spray in there to inhibit rust?
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Re: Drilling frame drain holes - cb750
« Reply #1 on: April 25, 2012, 08:42:40 PM »
I drilled back near the lower rear mounts, it seemed to be the low point at the time. I also welded a new left side tube on it, it was split from mount to mount, looked like it had been filled and frozen.
Offline lucky
« Reply #2 on: April 25, 2012, 09:15:16 PM »
It is not needed. If the tube is sealed up then no air can get inside the tube and it will not rust. I am a welder and have cut many tubes open and the ones that are sealed are not corroded inside. If water can get in the tube, then  a drain hole WOULD be needed.
« Reply #3 on: April 25, 2012, 09:19:08 PM »
That's the problem with the K0 and K1, it was a factory bulletin to the dealers but most didn't do it. These things have several places water can enter. I like my bike clean but I guess I should avoid a pressure washer.
Offline MoMo
  • Ride like you're invisible
« Reply #4 on: April 25, 2012, 09:39:26 PM »
Here are some photos of potential damage...Larry
« Reply #5 on: April 25, 2012, 10:17:01 PM »
Wow that's as bad as mine was.
« Reply #6 on: April 25, 2012, 10:20:44 PM »
The holes should be 7/32" to 1/8" size, just behind the forward motor mounts. Use CRC spray, or regular motor oil. Avoid WD40, it is made to ATTRACT water, and does it well!
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« Reply #7 on: April 26, 2012, 06:14:25 AM »
I drilled an early CB750 K1 frame that was missing drain holes and when I did, water came out - quite a bit of it.
Offline zzpete
  • You better get an
  • 1969 CB750, 1971 CB750
« Reply #8 on: April 26, 2012, 11:28:10 AM »
Wow!! I guess I should do mine!!!
"One of the things that make motorcycling so great because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
Offline lucky
« Reply #9 on: April 26, 2012, 11:40:01 AM »
And if water got in - then air can get in=corrosion.
