Author Topic: Is Yamabond acceptable for installing valve cover? KZ400  (Read 988 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: April 26, 2012, 02:22:11 PM »
KZ400's had these endemic oil leaks, and actually had a recall in the 70's to fix them. Of course nobody actually took their bikes in, so every one I've ever seen still leaks from the same places. The factory repair spec sheet calls for getting rid of the old "o-ring"and use a non-hardening sealant of some sort when reinstalling the valve cover after a rebuild. Is Yamabond okay to use?
Offline simon#42
  • liverpool
Re: Is Yamabond acceptable for installing valve cover? KZ400
« Reply #1 on: April 26, 2012, 03:20:42 PM »
i think it would be fine , have never used it on a kz 400 but have used it to good effect in similar circumstances
