Author Topic: 97 Harley Wide Glide question?  (Read 1981 times)
Offline dhall57
« on: April 28, 2012, 12:32:47 PM »
Other than just having sohc4 Honda's I know there members here like me that have Harleys also. Has anyone had this happen? Started it up the other day to ride it to work and within just a few minutes I noticed  smoke coming from the left side of case near oil filter. Of course I killed the engine as quick as I could. I looked down and saw where the voltage reg. pigtail plugs into the case was halfway melted away.What do you think, bad voltage reg. or stator or maybe both. Here's some pics.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Re: 97 Harley Wide Glide question?
« Reply #1 on: April 28, 2012, 01:03:06 PM »
 Nasty just search on line, should find root or probable cause.. good luck.. They used to sell a little cover to keep plug from working loose..
« Reply #2 on: April 28, 2012, 02:00:13 PM »
Can't say for sure but my bet would be the reg. If stator wasn't working properly would it put out the voltage to cook it? Make sure your reg hasn't worked loose and is giving a bad ground.
Offline grcamna2
« Reply #3 on: April 28, 2012, 04:23:25 PM »
Get a new set of electrical connectors and give it another try..it may have just loosened up as mentioned from vibration and shorted itself out;be good to test the charging output at you're battery terminals after that.Do you have a Shop manual for it ?
Offline Leino
  • Not much of an
  • in drag racing since 2005
« Reply #4 on: April 29, 2012, 03:22:15 AM »
I work in a Harley Davidson shop and my professional opinion is, there's no Harley-problem a gallon of gas and matches wouldn't solve  ;D
Offline dhall57
« Reply #5 on: April 29, 2012, 05:16:28 AM »
Leino, Well I guess there is no doubt what side of the fench your on when it comes to Harleys ??? I can't complain one bit though, 35,000 miles and all these years later this is first problem I've ever had ;)
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Offline Leino
  • Not much of an
« Reply #6 on: April 29, 2012, 10:30:51 AM »
Just kidding about burning them, but every Harley I work on makes me want one even less.
That goes for most modern Japanese and European bikes too so I'm not being picky  ;D
Don't tell Sam but I rode a Dyna with 8000km on the clock and it actually felt pretty good...
« Reply #7 on: April 29, 2012, 10:41:25 AM »
40,000 on my 2003 Fat Boy since new and not the first problem. Leino, what's your job at the Harley shop? Is it a Harley dealer or does your shop just work on Harleys? How are the newer Harleys doing versus the older Harleys?
Offline Leino
  • Not much of an
« Reply #8 on: April 29, 2012, 10:51:51 AM »
My actual job is to work on all non-Harley bikes but I seem to end up working on all bikes that roll in through the doors.
It's not official Harley dealer, just a shop specialized in them. Last week I was asked to fit a 200mm rear tyre on a Softail of some age and model, changed the narrow belt and everything, still didn't fit  ;D
The struggle continues tomorrow. Bikes owner told me to use any means necessary... sparks and beating coming right up  ::)
Offline Leino
  • Not much of an
« Reply #9 on: April 29, 2012, 10:59:01 AM »
To finally answer the original question, looks to me like the connection got loose and fried right up.
« Reply #10 on: April 29, 2012, 11:05:57 AM »
I'm sure working at a non-Harley dealer shop can really present some interesting situations. That makes you a master-of-all. Glad you're here with us. Someone asked me if I work on my own Harley. Told them I'm thankful that I don't have to learn how to since working on a 40 year old Honda is more than enough  :D
The earlier softtails had 150 tires then went to 180. Some may be at 200 now. My 03 is a 150.  "Any means possible" could mean a whole new rear end kit! You'd better ask what his spending limit is because it is possible. Thats one good thing about Harleys, they are designed to let you spend as much money on them "as possible"  ;)
Offline Leino
  • Not much of an
« Reply #11 on: April 29, 2012, 12:26:27 PM »
I'm the master of nothing  ;D
This particular softail... I pulled a 130 out of it, (stock swingarm) and he wants me to replace it with a 200.
Someone told him it's doable so I guess I'm gonna do it somehow  ::)
« Reply #12 on: April 29, 2012, 01:14:01 PM »
I told you you wouldn't it. ::)
