Author Topic: Re: Oil pan plug, hand-tighten or correct torque? NEW: oil pan bolts, same ques?  (Read 8644 times)
Offline Mercutiojb
 A few questions..
Just changed the oil on my 77 supersport.  Went to tighten the crankcase oil plug (to the correct torque), and I believe I may have busted the threads in the pan.  The plug seems to thread in and out just fine, but never really 'tightens'.  It gets all the way to the pan, then just sort of... spins.  If I were to keep spinning it, it seems to get harder, then easier, depending on how far around it is spun.
So, it looks like I'll need a new pan? (anyone have one for cheap?)
My question is, should I not attempt to use the correct torque setting? Should I just do hand tight plus a little extra? I've seen both recommendations in other threads here, but I'm not sure.
Also, can something like a lock washer be used in addition to the crush washer to keep the bolt from coming out?
Follow-up question - I've heard some people have found the crush washers for much cheaper at fastener stores.  What size would I need, and what should I be asking for?
« Last Edit: May 06, 2012, 09:17:26 AM by Mercutiojb »
Offline mono
  • Definitely no
« Reply #1 on: April 30, 2012, 09:46:27 AM »
from scouring the forums i have seen a number of posts about people putting the correct torque on something only to have it break.  i'm interested in the answers on this also.
when i changed my oil last summer after getting my bike, i tightened it by hand until it was tight, then gave it an extra nudge.  didn't leak a drop.  that said, maybe i just got lucky and that was the right torque amount. *shrug*
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: April 30, 2012, 09:51:47 AM »
I use hand torque only, I've stripped too many threads on my bike. I think 35 years of undoing and redoing bolts is going to weaken something.
« Reply #3 on: April 30, 2012, 10:00:05 AM »
I thought I posted here a moment ago, but it didn't take so here it is again.
My chart say 25 to 28 ft lbs on a drain bolt! No Way!
I have a code about crushables: like drain plugs, spark plugs, oil filter bolts, tappet covers, etc, with crushable washers: hand tighten then a good umph with a 6 inch wrench, you should feel the washer give, then STOP!  If it leaks, tighten a bit more till it stops.
You may find a self tapping drain plug from auto store. They use them when they strip a car oil pan.
You may remove your pan and repair the thread.
You can get crushable drain washers anywhere, just use metric so they fit nice. I buy from OEM, 10 at a time. Use a new one each time. The one in question is 12mm. At $1.48 you can do better, though that wouldn't stop me. Just look around for a different application that uses 12mm crush washer.
« Last Edit: April 30, 2012, 10:01:37 AM by MCRider »
Offline 2wheels
« Reply #4 on: April 30, 2012, 10:02:57 AM »
Hand tight , use a 3/8 drive ratchet . Which normally have a short handle.
I stipped mine last year doing the same as you.
I found a 14 mm thread plug.  Then had a local guy drill and tap the hole for my new plug.  Worked fine.   Cost 10 dollars total.
I did buy a new pan gasket but did not need it.
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
Hinomaru
« Reply #6 on: April 30, 2012, 10:21:59 AM »
Besides stripping the threads in the oil pan, over-torqueing the drain bolt can also cause a cracked pan.
This always results in a undesirable oil leak. :(
Offline Mercutiojb
« Reply #7 on: April 30, 2012, 11:07:10 AM »
I'm wondering if it's not cracked as well.  I hate to have to pull the pan, but if I have to, I have to.
It seems odd though, or maybe I've just never seen this before.  I've never seen a bolt that threaded in and out correctly, but just didn't tighten.  It seems to be holding at the moment, but I fear that vibration will shake it loose so I'm guessing the bike will be un-ridable until it's fixed?
Offline Dimitri13
  • 1974 CB550K
« Reply #9 on: April 30, 2012, 11:09:03 AM »
I stripped mine torquing it to.. 14ft/lbs or something. Tried replacing it with an oversized drain plug, only to have that not work well. I ended up replacing the oil pan for like $25 shipped from ebay. The best thing was that it had no chipped fins (mine had a small chip), and it was in overall better condition.
  • 1977 CB550F2
« Reply #10 on: April 30, 2012, 11:11:54 AM »
Cheap as I am, I would epoxy it until you get a permanent fix arranged. :)
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #11 on: April 30, 2012, 11:16:38 AM »
hand tighten.
Offline Mercutiojb
« Reply #12 on: April 30, 2012, 11:17:24 AM »
I think I may end up doing just that!
Offline Mercutiojb
« Reply #13 on: April 30, 2012, 11:18:13 AM »
As long as I can get the plug to stay in, I wouldn't mind!
  • 1977 CB550F2
« Reply #14 on: April 30, 2012, 11:19:44 AM »
Clean it up, wrap some plumbers tape around the threads and epoxy it. :)
Offline Mercutiojb
« Reply #15 on: April 30, 2012, 11:34:15 AM »
As in "you're never getting this bolt out again after you epoxy it in"?  Just want to make sure I'm not missing something  :D
  • 1977 CB550F2
« Reply #16 on: April 30, 2012, 11:37:19 AM »
Epoxy will easily chip off, I've done it before. I mean to epoxy around the area once the bolt is inserted.
« Reply #17 on: April 30, 2012, 11:49:10 AM »
There is just enough thread left in the aluminum to fool you. But don't let it. It won't stay. I'll second my idea on the self threading repair drain bolt from auto land. They may not have one close enough to your size, but worth a phone call or trip if close.
Offline Mercutiojb
« Reply #19 on: April 30, 2012, 11:57:58 AM »
I'll check this out first!
« Reply #20 on: April 30, 2012, 12:04:45 PM »
This discussion made me read up on self tapping plugs. Many threads from other motorsports forums, all with good feedback. Plug comes in .5 mm increments so you'd get a 12.5.
Some of them are piggy back. That is they have an actual but smaller drainplug in the center. So onceyou get the bigger portion in you never remove it. Just pull the center smaller plug to drain with.
Caution: I've never used these or known anyoone who has. i just know they are out thre.
Offline Mercutiojb
« Reply #21 on: April 30, 2012, 12:13:04 PM »
Anyone have an idea on the original thread pitch of the plug?
« Reply #22 on: April 30, 2012, 12:28:54 PM »
I will in a minute.
12mm x 1.5
« Last Edit: April 30, 2012, 12:32:51 PM by MCRider »
Offline Mercutiojb
« Reply #23 on: April 30, 2012, 12:39:32 PM »
Thanks for all the help MCRider!
I will in a minute.
12mm x 1.5
Offline lone*X
« Reply #24 on: April 30, 2012, 03:03:16 PM »
The idea of a piggy back plug is a good one.  You would then have steel drain plug in steel threads.  Would not have to stress the aluminum pan anymore.  Sort of like doing a helicoil.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline lucky
« Reply #25 on: April 30, 2012, 06:17:54 PM »
Does the bolt have the aluminum washer on it????
If not what is happening is the bolt goes up into the pan and then goes past the threaded part because the washer is missing. Just a possibility.
Offline lucky
« Reply #26 on: April 30, 2012, 06:20:28 PM »
Take the pan off and fix it right!!!
Chhheeeeesssshhhh!!!!
« Reply #27 on: April 30, 2012, 07:12:52 PM »
The pan is broken (stripped). One can analyze one's options to fix it. Why is a helicoil more right than a self tapping plug? I've seen helicoils go dreadfully wrong.
The car guys don't think twice about using a self tapping plug. Are they all wrong?
The OP may opt to remove it and do a thread repair.  He may put a ST plug in so he can ride and wait till he can score a new pan off eBay. Or they may not even make the appropriate ST plug for the application.
My point is, there are many "right" ways to fix this.
Its time to go riding. Short season in Mn.
« Last Edit: April 30, 2012, 07:16:40 PM by MCRider »
Offline Mercutiojb
« Reply #28 on: April 30, 2012, 07:46:25 PM »
I did find a piggy back plug, and I can post a reply here when I've seen if it will work or not.  I agree with MCRider in that these are used on cars all the time, so for a temporary solution, it's at least worth a shot.  If it doesn't work, I'm no worse off.  I need a new pan either way.
If it works, I'll wait for a new pan at a good price, and fit it when I can.
« Reply #29 on: May 01, 2012, 05:11:29 AM »
In my searching on the subject, i found a forum on the HondaCB1.org site, where an individual had stripped their pan. They too found a piggyback plug and reported on its install. They threaded it in without the washer till it almost seated. Then removed it. A small amount of shavings were trapped in the interior of the plug. It was evidently designed to do that. He cleaned the plug reinserted with the washer, and went riding.
Good luck!
Offline Mercutiojb
Well, the plan went like this:
No one in town carried a piggy back M12x1.5 self tapping plug.  From my research, it seems that most people have been successful using a M12x1.75 self tapping plug.  No one in town carries a M12x1.75 piggyback, but I could get a 'standard' style oversize plug (Oil-Tite! brand)  The plan was to use this until the next oil change, when I would replace it with a piggyback style plug.
The good news: The self tapping plug seems reasonably easy to use.  I did as suggested on this forum.  I used thread cutting oil (though I wonder if a heavier grease would have been better?) and threaded it in in stages.  I pulled the plug back out, cleaned any shavings off the threads, re-oiled, and continued on.
The bad news: When I had the plug nearly in, I heard a distinct 'snap'.  I stopped, checked, and now have a large crack where the plug goes in.  I believe it may have been slightly cracked before, but this was too much for it.
So, I believe the self tapping plug may be a good temporary solution if the pan is confirmed to not be cracked.  But, sadly, it didn't work for me.
Sigh!  I feel like I'm breaking more things than I'm fixing!  I guess I'm on the hunt for a new oil pan now.  I hear the oil pan mounting bolts can be iffy as well, any suggestions? Should they be hand tightened or torqued to spec?
Sorry about that.  :(
Offline Deltarider
Tip: use a torque wrench only where it really matters (head).
For the rest use your sense and keep your skills.
CB500K2-ED Excel black
  • 1977 CB550F2
Get that crack welded up.
