SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
helicoil or longer bolt
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: helicoil or longer bolt (Read 1263 times)
aberle
Full Member
on:
April 30, 2012, 10:40:24 AM »
Ok so at the tail end of my top end rebuild on my 74 cb750 I striped one of the cam tower bolts that keeps the rocker ARM shaft in place. I did notice once I took the head back off the bike the striped hole still had some good threads that the bolt couldn't reach, so my question is should i helicoil it our just get a longer bolt.
Any input would be appreciated.
Logged
SOHC Digger
I'm not an
Expert
Re: helicoil or longer bolt
Reply #1 on:
April 30, 2012, 10:43:01 AM »
Heli-coil. Do it right.
Logged
The surest way to learn is to make a mistake.
1978 CB750F Chopper/Digger
Amen Chopper Project
$100 Carburetor Rebuilding Service
Elan
Expert
Reply #2 on:
April 30, 2012, 10:56:52 AM »
not to take over this thread, but can anyone confirm the length of that bolt? it doesnt say in the parts diagram, and I have 2 sizes in mine!
Logged
k6 build
http://forums.sohc4.net/index.php?topic=79833.0
76 750k
aberle
Full Member
Reply #3 on:
April 30, 2012, 11:18:07 AM »
What size heli coil would that be I'm only asking beacuse iv never used one before.
Logged
lucky
Really Old Timer ...
Reply #4 on:
April 30, 2012, 11:32:59 AM »
Take the bolt with you when you go to buy the helicoil or when online the bolt size will be listed with the corresponding helicoil and drill size.
Time serts are good too.
You might be able to get them at a local machine shop and save shipping charges.
Logged
cmonSTART
Hot Shot
Reply #5 on:
April 30, 2012, 11:34:42 AM »
Most of my local auto parts stores have heli coil kits right on the shelf. They're pretty easy to do once you've done a couple. Personally I wold go that route.
Logged
1981 GL1100 Interstate
1978 CB750F Project
lucky
Reply #6 on:
April 30, 2012, 11:35:11 AM »
If you use a longer bolt and it bottoms out in the hole and you tighten it ,then it will strip that out too. You do not want the bolt to bottom out in the hole.-LUCKY
Logged
SOHC Digger
I'm not an
Expert
Reply #7 on:
April 30, 2012, 11:37:25 AM »
I believe they are 6mm bolts.
Logged
cwchan
Enthusiast
Reply #8 on:
April 30, 2012, 11:42:07 AM »
i had a similar problem. i measured the depth of the hole using a longer bolt to see when it would bottom out. There ended up being 8mm more depth that the stock bolt wasn't catching so i got a bolt that was 5mm longer than the stock bolt
From what i measured, the stock bolt only caught 5mm of threading.... but different holes could be different
Logged
http://forums.sohc4.net/index.php?topic=76674.0
Plummer
Full Member
Reply #9 on:
April 30, 2012, 03:16:25 PM »
M6-1 autozone , comes with the tool and the tap . 1/4 " bit needed ,6.3mm. Yes 2 different sizes of bolts , that is how I stripped mine LOL !
Logged
Every Day Above Ground Is A Good One !!!!!
aberle
Full Member
Reply #10 on:
May 01, 2012, 06:44:35 AM »
Ok i got the kit and am putting them in at work. But i got the 4 cam tower bolts and the 4 head bolts mixed up. I think the longer ones with the letter b stamped in the top are the head bolts, am I right?
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
