Author Topic: CB550K exhaust gaskets  (Read 686 times)
Offline PrsCustom22j
  • "they've done studies you know...60% of the time it works every time"
« on: April 30, 2012, 06:36:51 PM »
today i decided to change my exhaust gaskets on my CB550K and noticed the old gaskets looked nothing like the ones i ordered off bike bandit...which are copper ring shaped.  after replacing and putting in the new copper ones on, i noticed white smoke coming off the engine where the pipes connect when i started it.  what is causing this?  it's didn't smoke before i changed them.
thanks in advance,
John
these are gaskets that were on the bike
1976 Honda CB550K
Re: CB550K exhaust gaskets
« Reply #1 on: April 30, 2012, 10:41:16 PM »
the smoke will be greasey finger prints etc,as well as the new gasket itself somewhat.
Offline Lavis500
  • Why don't you go ask a
  • "Don't plan vast projects with half-vast ideas"
« Reply #2 on: May 01, 2012, 03:10:36 AM »
When those gaskets were new, they probably didn't look too different from your current new copper gaskets.  It's just a crush gasket, so it takes the shape of the gap when you torque it down.  Like Dave500 said, it's just residual stuff burning off.  Give it a while, it should go away.  If not, maybe double check the specified torque to make sure it's properly sealed.
"Whatever it is, I swear I didn't do it!"
'73 CB500 - Sally
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #3 on: May 01, 2012, 03:01:15 PM »
careful tightening down the exhaust studs they have a tendancy to pull out when over torqued.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #4 on: May 01, 2012, 04:10:47 PM »
thanks for the input everyone.  i'll double check to make sure they are sealed properly and torque to the correct specs.  hopefully its just its just the greasy finger prints burning off like mentioned cause i'm ready to get this thing road.
- John
1976 Honda CB550K
