Author Topic: How do I properly measure across my rim(s)?  (Read 836 times)
Zane
« on: June 09, 2006, 08:13:37 PM »
Duh!
It sounds easy, but what throws me is the thickness of the actual steel on each side (the rim proper, I guess).  It's a smidgen over 1/2 an inch.  +/- a full inch for an under three inch measurement is a little too imprecise I'm thinking.
My guess is the measurement would be taken from center to center.  But it could be inside or even outside I suppose.
I checked a few tire sights, but no joy ......
Anyone know for certain?
Offline Bodi
Re: How do I properly measure across my rim(s)?
« Reply #1 on: June 09, 2006, 08:29:51 PM »
The inside measurement is what counts to the tire, and a 2.00 wide rim will be 2.00 inches from inside flange to inside flange. The flanges are usually tapered, I don't know if the exact measurement is at the bottom top, or middle of the flange; the difference would be minimal anyway.
Zane
« Reply #2 on: June 09, 2006, 08:36:37 PM »
Yeah, the taper is minimal.
And it makes sense when you consider it like you say - from the tire's POV.
Inside it is then.....
Thanks a lot ....
z
