So if i'm putting the engine back together, what do i do to seal the gaskets in the best possible way? And I ordered the towers Elan found on Ebay. Should I do the oil mod or not? What are your recommendations? Still looking for a camshaft though.. Found some k4 ones, they look the same, except for the cam chain sprocket, which, in 74', didn't have holes in it. Is it safe to use one of those on my 78' bike?
Thx
If you're asking me... but there are several here with just as good advice.
Use a non-hardening type gasket sealer, like Gasgacinch. It will say "non-hardening" on its package. Realize that many here will say put them on dry, or lightly oil them, or use the NH sealer on one side only to set the gasket (that's me) or both sides. All of these methods work. You're pick. Most important: DO NOT USE a silicone based sealer that hardens. I like the one side method as much for convenience of sticking them in place, and for removal of the cover. The gasket will stick to one surface and not the other so it can be reused. No need for sealer if sealing is the only issue, IMO.
With the NH sealer, put on a very light coat and let it set for a few minutes to get tacky.
As to the mod, can't beat HondaMan for the tricks. I didn't do it as the bolts from my reinforced rocker box hits the same spots he drills. If you feel up to it sure why not?
As to the sprocket, holy or not, I can't see a reason not to use it, but i don't have first hand experience. I have some cams and sprockets, I'll see if they are holey tonight if you can wait that long.
Do you know why yours seized? Are the oil orifices in the head blocked? Is the oil pump screen clear?
