Author Topic: Pulling wires through clubman bars  (Read 1499 times)
Offline shorty24
« on: May 04, 2012, 05:35:37 PM »
Is there some trick to this that I don't know about?  I can't for the life of me get the thick bundle of wires on the clutch side to go around the sharp bend inside the clubman bars.  And nothing I can attach to the end of the wires to help pull them through is strong enough or attached well enough to help me assist in pulling the wires through.  Any help would be appreciated!
Offline jamesb
Re: Pulling wires through clubman bars
« Reply #1 on: May 04, 2012, 06:08:30 PM »
do what i did bet my son 10.00 that there is no way in hell he could get those wires through there well about 45 minutes later he comes in and says pay up and both of us walked away mumbling sucker. i found out he used dish soap taped up the wires real tight with black tape with a piece of bailing wire in it. make sure that you taper the end to a point they are even worse when taking them out mine where in there for about 5-6 years i took them out a couple of weeks ago went with drag bars instead and it was very difficult pulling the wires out.i guess from sitting in there and the heat and age stiffended them up
Offline CycleRanger
  • No comment about being an
« Reply #2 on: May 04, 2012, 07:06:38 PM »
Try some aqua gel cable pulling lube.
Offline shorty24
« Reply #3 on: May 04, 2012, 09:50:19 PM »
I taped 'em really tight and sprayed some chain and cable lube on them, and guess what...they pulled right through.  Thanks for the help guys!
Offline brandEn
« Reply #4 on: May 04, 2012, 09:53:58 PM »
my buddy helped me and we used weed eater string and wd40. Worked great
« Reply #5 on: May 05, 2012, 07:44:13 AM »
Petroleum may soften the insulation, soap or real wire pulling gel is best.
Offline Rgconner
« Reply #6 on: May 05, 2012, 11:58:53 AM »
That's what she said!
Sorry... It was just too easy.  8)
1975 CB550K aka "Grease Monkey"
Offline andrewk
  • doin' it.
« Reply #7 on: May 05, 2012, 03:43:04 PM »
When I worked as a commercial electrician we carried around 5 gallon buckets of this stuff-  I always said when putting it back in the van, "looks like 3.5 gallons of fun left!"  :P  If you can't find the gel, most home stores sell the ideal brand pulling soap- it's good stuff too.
Offline phil71
« Reply #8 on: May 05, 2012, 04:28:32 PM »
Aside from the soap, I like to make a 'cone' on the end, where each bullet is just behind the other, so it's smaller..  then tape 'em together that way.
Offline 6adan
« Reply #9 on: May 05, 2012, 07:47:36 PM »
I have also painted the inside before pulling the wire. The paint makes a little smoother and keep it from rusting.
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
