Author Topic: Need to replace the piston pin clips?  (Read 679 times)
Offline killersoundz
« on: May 05, 2012, 08:18:02 PM »
Is it necessary to replace the little piston pin clips that hold the piston pin in the connecting rod? Already snapped them back in place once pretty sure I can again, may become slightly deformed but not too bad. For so cheap I should probably just replace em' then?
My project thread:
http://forums.sohc4.net/index.php?topic=107447.0
My CB750K4 Starting up for the first time after a seized motor and rebuild!
Re: Need to replace the piston pin clips?
« Reply #1 on: May 05, 2012, 08:45:24 PM »
ive used them over and again once or twice,ok if they havent been distorted,,not best practise,new ones are cheap,i promised myself next order from david silvers id get a few sets.
