Author Topic: cross threaded spark plug  (Read 7133 times)
bollingball
Re: cross threaded spark plug
« Reply #25 on: May 10, 2012, 06:16:26 AM »
One bit of advice i would like to add from my experience. If yo do any of these procedures withthe head on, hook a vacuum up, set to blow and put it on the exhaust port with th exhaust open. You can just tighten the valve if the piston position worries you. Just remember to put it back. This will blow most of the metal in your face so safety glasses are a must.
I like this way the best. Then clean up with vac.
Ken
Offline trueblue
« Reply #26 on: May 10, 2012, 01:48:30 PM »
I think doing this also is a good idea but I would rather keep it out of there in the first place. I would do this after to pick up as much little crap as possible. No matter the method its sure to leave a certain amount of crap in the cylinder.
Exactly, you will always end up with swarf down in the cylinder, even if you grease the tap, and it can never be too clean.
1979 CB650Z
Offline coke
    • Bob and Bob Bikes and Cars and Rides
« Reply #27 on: May 10, 2012, 05:47:26 PM »
Thanks for all the advice.. I am a wuss and decided to just have a mechanic do it since I have to use it this the 18th for the next leg of the world tour relay part 2
1974 Honda CB350F
1976 Honda CB750F
1977 Honda CB750 F2 SuperSport
2009 H/D VRSCAW VRod
2011 H/D Road Glide Ultra
2007 Kawi 650r Ninja
1999 HD 883 Sportster (bought back from youngest son)
1999 Kawi 1500 Nomad (given to oldest son)
