Author Topic: My 2nd CB650 project... This one with a build thread.  (Read 16562 times)
Offline goldarrow
  • one day, i'll be an
« Reply #25 on: September 07, 2012, 08:22:36 PM »
Simplegreen or pine-sol always works great
CB550 K0
Offline onepieceatatime
Re: My 2nd CB650 project... This one with a build thread.
« Reply #26 on: September 14, 2012, 06:23:17 PM »
I did a little more on that nasty set of carbs today.
I had to use a hammer and punch to get the float pins out. Then pliers to pull the float needles. I pulled the slow jets using vice grips.
I am still not ready to disassemble this rack. probably during the next cleaning session.
Here is the rack after sitting in simple green for 10 hours. Only 3 of the 4 would fit into the container I had.
The 3 floats that soaked and the 1 that did not:
The little bits (I kept them separated by carb)
and the slow jets
It is obvious that much work remains to be done. After I have gotten most of the crud out using simple green, I will finish the clean up with carb cleaner.
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
