Author Topic: 1976 550 front brake light switch  (Read 1173 times)
Offline andymum
« on: May 11, 2012, 03:59:07 AM »
Hi does anyone know where it is how it works is it required through age for mot "uk" cheers
Offline LesterPiglet
  • 1977 CB550F2
Re: 1976 550 front brake light switch
« Reply #1 on: May 11, 2012, 04:05:31 AM »
The switch should be attached to the brake line on the lower triple/yolk. You need a working brake light for MOT but the rear one will do.
Offline andymum
« Reply #2 on: May 11, 2012, 04:39:44 AM »
oh cool so is the front one powered ie little ball bearing moves with brake fluid
Offline andymum
« Reply #3 on: May 11, 2012, 04:45:25 AM »
Hi thanks for that have solved problem previous owner put wires around wrong way all fixed now thanks again
