Author Topic: <tilting the engine  (Read 1267 times)
Offline totmotors
<tilting the engine
« on: May 13, 2012, 04:20:35 PM »
Hi guys, i´m going to use a CB650 engine for a conversion and it will needed to be tilted forward, is not going to get abused neither given a hard time.
My question is the following, how many degrees do you think i can tilt it safely forward?
Thanks a lot
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: <tilting the engine
« Reply #1 on: May 13, 2012, 09:50:30 PM »
I would think not much (5-10 degs?), since the lubrication system was designed for the angel at which the engine sits in a stock frame.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline turboguzzi
« Reply #2 on: May 13, 2012, 10:14:29 PM »
will let sam decide if this is hipo or not... sounds iffy :)
just for starters, when people jack the back of a road race bike for quicker steering, they can easily tilt the whole bike motor included by a good 4-5 degrees.
More? oil pick up point can be modified, moved and the sump deepened with a spacer, etc, not a problem if you are hard core hipo ;)
will surely look odd, but hipo's can take it
« Reply #3 on: May 13, 2012, 10:30:37 PM »
Question answered Yossef and NO, off it goes to Tech Forum.
Sam. ;)
« Reply #4 on: May 13, 2012, 11:47:00 PM »
no more tilt than the bike could ride up or down if it was a long steep hill?
