Author Topic: 1972 CB500 hasnt ran in 15 years...  (Read 21415 times)
Offline samIam
  • 72 Honda CB500 Four
« on: May 14, 2012, 06:21:57 AM »
Hey all, new guy with some questions.  I'll start by saying I know nothing about bikes, never rode one and never worked on one.  I am a young-ish mechanic and I've build a few motors but never touched a bike.  I just got this 72 CB500 that hasnt ran in 15 years from someone as a payment for work done, about $300 worth of work.  As soon as I got the bike, I started taking it apart.  The goal is to get it running without spending a lot of money and to not have to open the motor.  Motor spins pretty easy and I took a plug out and saw a decent chamber.  The only valve I could see come down was in decent condition, also.
My son really likes it, wife told write a will
What I've found so far...rusted tank.  I've got vinegar in it now to soak.
Brake fluid completely dry
Been laid down?  Seems like there would be more damage
Handle bars bent
Got the carbs off and opened them up...
Three of the four bowls looked like this
This one has corrosion inside, can anything be done about it?
Clutch plates move when I pull the lever but only a couple on the outside.  Been told they will free up eventually and the main thing is that they arent froze in place
Points look good, alt looks decent.  Hopefully they work
Here is the gear selector foot lever, the rod that it is attached to has major damage and someone just drilled a hole and did a cotter pin type setup. Works pretty good.  I really dont want to open the motor up to replace it.
The wiring looks ify at best.  Some wires look like they were pulled out of connectors and some arent connected to anything.  I'll have to get some more pics of the wiring because I'm hoping its still good.
Anyway, thanks for letting listening, hope y'all see any easy process to get it running
Offline fmctm1sw
Re: 1972 CB500 hasnt ran in 15 years...
« Reply #1 on: May 14, 2012, 06:42:47 AM »
I don't own a 500 but...
carbs:  I've seem far worse.
instrument cluster off a later bike?
Master cylinder and brake caliper frozen?
yeah, looks like some wiring oddities.  Did it have spark?
you have your work cut out for you but I've seen (and owned) worse.  Welcome to the board, easily the best resource for SOHC Honda bikes on the net.
*edit*  You might be able to push that gear selector shaft right through the right side of the case if you take the clutch basket off and undo the shift linage under it.  Something tells me I did that with an old CB175 I had with the same clutch set up.
« Last Edit: May 14, 2012, 06:45:48 AM by fmctm1sw »
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline mono
  • Definitely no
« Reply #2 on: May 14, 2012, 06:46:44 AM »
welcome!
wow the cooling fins on the engine look like they took the brunt of the damage from whatever caused the points cover to get scuffed... yikes.  but as long as there aren't any structural cracks in it, you're probably OK.
-the carbs (which look amazingly clean on the outside!) can be cleaned.  that grossness inside the float bowls is probably from the tank.
- may want to replace the brake lines if everything's crusty, and maybe a master cylinder rebuild.
- the electrical looks like it's been seriously hacked at.  also, the those front turn signals are pretty interesting...  :o
for the equivalent of $300, i'd have taken it! :)
« Last Edit: May 14, 2012, 06:48:46 AM by mono »
Offline dhall57
« Reply #3 on: May 14, 2012, 07:01:00 AM »
Welcome from North Carolina. The smile on your sons face says it all. Motor spinning freely is a BIG Plus. On the negative side, tanks rusted pretty bad, and looks like one of the PO's did there best to destroy the wiring >:( along with the shifter shaft. Everything else not bad. I've seen and along with everyone else here have seen a lot worse for sure. Like most of these 35 to 40 year old sohc4's just needs some T.L.C. Good luck and keep us informed on your journey to get it back on the road ;)
dhall
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline LesterPiglet
  • 1977 CB550F2
« Reply #4 on: May 14, 2012, 07:04:42 AM »
Normal Honda indicators for that year I think. They are also on 750's and my 550F.
Offline samIam
« Reply #5 on: May 14, 2012, 07:48:21 AM »
Thanks for the replies.  I'm hoping to get it running by changing the oil, plugs, battery, cleaning the carbs and tank.  Think that will work?  Also, if anybody has any parts I need, let me know.  So far I need handle bars, plugs, carb rebuild kit, tires, driving lessons, liscense, experience and a convinced wife.  lol
Offline mono
  • Definitely no
« Reply #6 on: May 14, 2012, 08:09:18 AM »
oh i thought it looked like they were mounted a little far forward.
Offline vames
« Reply #7 on: May 14, 2012, 10:25:03 AM »
Wiring looks like it's going to be the hardest thing to get back to normal. A word to the wise: don't mickey mouse it back to just for the cheap thrill of getting it running. If there are busted connectors or chunks of wiring, bring it back to stock. You can get replica bulk and bullet connectors for relatively cheap at www.vintageconnections.com. You and future owners of your bike will be very thankful if you don't hack and patch just to get it running.
bollingball
« Reply #8 on: May 14, 2012, 10:52:26 AM »
They do look a little odd if you look at the 2nd pic. it looks like they should go in that hole closer to the tubes. But I don't have a 500.
Looks like you might have a good helper.
« Reply #9 on: May 14, 2012, 11:58:11 AM »
The front blinkers are mounted in the original position.  But, those aren't the original fork cover ears.  Those are probably from a CB550.  The forks were likely replaced after the accident that the bike suffered through.  Front fender is from a 77-78 model.
I'd certainly make some measurements to be certain things up front are straight and the repair work was done correctly.
Bars are bent.  If this was the result of the same accident, it would indicate a non-professional/incompetent repair, done on the cheap.
Clean the tank, (electrolysis would be my method of choice (fuel valve removed).
Clean the fuel valve.
Clean the carbs (don't forget the main emulsion tubes)
I'd get the proper 5.5 mm fuel tubing to replace that nasty "clear" stuff".
Make sure there is oil in it, and it should be ready to start up.
Put a good battery in it.
Set the point gap and static timing.
If the key switch won't provide power to the coils, then jumper from there to the battery POS terminal and the bike should kick start.
Do front brake overhaul.  (See FAQ)
Address chain and sprocket status.
Tires may be good enough for around the block.  But, I'd not be comfortable above 50 MPH on them.
Sorting the electrics just takes some patience and a wire diagram in the Honda shop manual, which is a must have.
Should be a fun bike, and not very difficult to get road worthy.
Offline samIam
« Reply #10 on: May 14, 2012, 12:28:25 PM »
Thank you for the insight, never would of thought about stuff being replaced after an accident.  The headlight is not on tight, at moves around when you tap it.  Anybody got some handlebars and a mount for the headlight?  I was looking in the parts for sale section but I'm not sure what years and models I can use parts from.  What type of measurement should I make?
For the tank, the vinegar has done wonders.
Fuel valve needs gaskets
Can I stick the carbs in carb cleaner complete like pic below?
Clear gas lines are gone now.
Gap and points are new to me, gonna need some help there.
Chain and sprocket "look" good.  How do I tell?
Tires are from 95 and look scary.
I see two nipple between the two middle carbs that had nothing connected, vents?
Offline Deltarider
« Reply #11 on: May 14, 2012, 12:41:33 PM »
Your carbs are not bad. BTW, no need to separate them (ever).
CB500K2-ED Excel black
« Reply #12 on: May 14, 2012, 12:59:38 PM »
those are vents,just put some hose on them and route them downwards,the gear shaft can be pulled through from the clutch side once the basket is off,lots of bikes are like that,drop the pan and desludge it aswell.
Offline fmctm1sw
« Reply #13 on: May 14, 2012, 01:04:47 PM »
On the carbs, there are folks that totally disassemble and those who are against it.  Yours don't look bad enough to be totally disassembled in my opinion.  In the 350 carbs at least, there are little felt washer things on the arms of the throttle slides.  I don't know that dipping the whole rack is a good idea.  But again, your carbs don't look bad.  I'd just make sure the passages are clear.  You can measure the chain.  I had a post here with a couple stretched chains and a good one but without the search function, it may be tough to find it.  Those open nipples are an atmospheric pressure source to your bowls.  Typically there are hoses on there that route up toward the airbox.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #14 on: May 14, 2012, 02:17:22 PM »
Probably an assembly error.  There is supposed to be a rubber washer between the headlight shell and "ear mount".
It can be tricky to the get the turn sig. posts tight enough and still be able to adjust the head light position.  Probably why the turn sig posts were mover to another location on subsequent models.
What is your goal, stock positioning?  Or, low uncomfortable "race" bars?  ;D
What width, rise, and pull measurements do you prefer?
Watch out!  Vinegar eats base metal as well as rust.  Can you say pinholes?  Vinegar won't eat through the paint from the inside, but it will metal.
I wouldn't.  You do have the Honda gasket set/kit for them, right?
16010-323-315
I'm reluctant to type that out yet again.  It's been described in many threads on this forum.  And is in the owners and shop manual.
How far can you pull the chain away from the sprocket mid curve radius?
Yes vents, should have 3.5mm tubing routing back and down between engine case and swing arm pivot.
Offline samIam
« Reply #15 on: May 14, 2012, 06:35:56 PM »
Well I'm glad to hear that y'all think the carbs dont need to be rebuilt.  Wasnt looking foward to that.  I'm just gonna get the gunk out and call it a day.  Everything that I can see inside of them look good.  Anybody got a carb kit?
For the handle bars, the stock ones feel good.  Never really thought of position.  I'm 6' tall, 245lbs...that got anything to do with handlebars.  Just want something thats easy to learn on.  Stock ones feel good, though.
The vinegar has done a good job and it seems ready to be done.  I'll get it out of there and take a look around.  Also saw a pic of the fuel cutoff valve/petcock(?) and it looks like there is a little tube that goes into the fuel tank, mine doesnt have one, like it broke.  It doesnt leak.
I'll check around for setting the points.  I'll also check the chain.
« Reply #16 on: May 14, 2012, 06:55:38 PM »
Do remove the pilot jets and clean them.  Just might be all the "rebuild" you need to do.
Personally, I'd also push out (toward the bottom) the main emulsion tubes that are behind the bottom main jets, to verify they are clean.  The place where you push is in the carb throat where the slide needle pushes in.  Be careful with the needle AND the hole where it pokes in, as that is the needle jet.  Don't want that damaged.
Offline samIam
« Reply #17 on: May 14, 2012, 10:18:00 PM »
So I think I broke something off the carb.  I was getting the old clear gas lines off when the nipple came off with it.  How do I fix this?
You can see the one on the right, I broke the left one.  Well, I dont know if it broke or is supposed to be able to slide out.  There was gasket/hardner stuff around it came off.  A previous repair or stock setup?
TwoTired, I'm trying to think about where you are telling me to push but cant picture it.  I dont see where I would actually push.  You are talking about the piece in the middle of this pic below, right?
Almost forgot, I bought a battery for it and the headlights/brakelights work, not the blinkers that I can tell.  electric start turned the motor over nice and healthy.  Got me excited to finish the bike.  Tank is drying, need a carb gasket set, fuel lines, oil change, run through brake system and test ignition system.
« Last Edit: May 14, 2012, 11:03:33 PM by samIam »
« Reply #18 on: May 15, 2012, 12:03:48 AM »
Ouch.  That''s gonna be more work.  I went out to checked my spares.
Between the carbs is a T fitting.  The nipple is soldered or brazed into a barrel that fits between the outer carbs.  To do the repair justice, I would remove the outer carb from the connecting plate to get at/remove the barrel.  Then at least use silver solder to mend the T fitting, inserting the nipple back into the barrel.
You'll need 4 orings for the barrel during the refit.  They will be in the 16010-323-315 Honda rebuilt kit.
On the center post is the main jet in your picture.   It is likely glued in with dried gas along with the oring that seals jet to carb body.  Don't expect to reuse that oring.  With pliers, pull that straight out and you can see the flat end of the tube to move next.  Now look in to the carb throat and open the slides as far as you can.  You will see a needle extending from the slide and a brass nub that the needle fits into.  That brass nub is the other end of the tube you saw under the main jet, and what you have to push on to get that emulsion tube out of the carb body.  Review my notes in prior posts about avoiding damage to it.
Do get yourself some aerosol carb cleaner and clean as much crud as you can from the bowls and the parts that reside in the bowls.  Also, scrape off that corrosion so it can't flake off later and plug that tiny .016 inch pilot jet orifice.
Have you checked the float for free swinging and the smooth float valve movement?  Do the float valve needle spring pins move freely?  If not, bathe them in carb cleaner.
Offline samIam
« Reply #19 on: May 15, 2012, 06:05:46 AM »
I tried taking a carb off once already and couldnt get it off.  I took the two main screws off the plate that connects them but couldnt see what else needed to be done to get it off.  I was thinking I could push the nipple back in and use JBWeld to hold it there.
Offline Deltarider
« Reply #20 on: May 15, 2012, 06:51:25 AM »
Yech, they look dirty, still no reason to separate carbs.
Offline samIam
« Reply #21 on: May 15, 2012, 07:05:15 AM »
Well I have to take one off the rack because I broke the fuel inlet T-fitting.  I did see the procedure in the manual, I'll try it.
Offline fmctm1sw
« Reply #22 on: May 15, 2012, 07:53:46 AM »
If you remove all 8 of those phillips screws the 4 carbs will come off of that backing plate as a unit.  To separate the carbs, you will need to unscrew those bronze looking (after you clean them) hex nuts near the very top.  Under those hex nuts are some very small pieces that need to come out to separate the carbs.  The tubes TT mentioned are under (or above, whichever way you look at it) the main jets.  Sometimes you can take the main jet out and pull them out (or they fall out) from the bottom.  I've used a Q tip to snag some of them.  You probably won't be so lucky though.  The throttle slides will need to come out in order for you to tap on them from the top.  I'm not sure of your level of ability but splitting a carb rack may be a bit aggressive if you've never done it.  Also, once you pull one off, the o rings on those little barrel connectors may start to leak, mine did.  Take a lot of pictures.  Maybe do a search for some other carb threads.  I know I have a couple that show my carbs in various states of disrepair.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline samIam
« Reply #23 on: May 15, 2012, 09:43:10 AM »
I got them apart, wasnt too bad.  I'm gonna get the emulsion tube out so hopefully they come out from the bottom.
Offline fmctm1sw
« Reply #24 on: May 15, 2012, 09:58:31 AM »
Good deal...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
