Sure Frank. those custom valves were for a LSR bike. The F2 has a different stem length secondary to the fact they are deeper in the chamber. I would change the keeper groove height too to get more spring into them. That's in hindsight. I'm confident you could get that valve in 35mm though you'd have to sink it pretty good to avoid valve to valve problems with a large cam
Sinking the valve(s) shouldn't be an issue. Just wondered about it working on the seats. Yes, blank stems would need the keeper groove custom cut for the correct installed height of the springs. Unsure of the requirement of the seat pressure/installed height on the KPM or APE SOHC springs. I need to see what the existing installed height is on the head right now and be sure thats duplicated by the machinist should i choose to go this route. I don't race the bike much anymore but i'm still very curious as to how quick i can eventually make it without adding nitrous or one of those high dollar Cycle X heads. I intend to concentrate on cutting weight off the bike to begin with. Those stock wheels will be the first thing to go along with the heavy stock rotors and the 630 chain. Rider might need to ditch a few pounds as well.
I'd like to see low 10's at some point before i loose my ability to swing a leg across the seat. Anybody have a stroker crank and some golden rods they want to donate to the effort?
Frank....getting the keeper groove height is very important because you really cannot shim the 5mm springs more than .030. The problem is the guide height is very low and there isn't enough material to stabilize the spring base if you go over...we'll say .040 in shim. I would move the keeper groove down .020 or so.
I'm confident 35mm will fit on the seat but I'll go over it with the fella that does my head machining...that won't be until, at least, next Tuesday.
You need some spring in there as that valve will weigh with the original profile in place. They really aren't that light. Ti would be really nice. If I were to do it again I would have a batch of guides made with more material for height. There is enough clearance for .500 lift so adding another .040 for shims is nothing. Offhand I'd say coil bind would be a non issue as well.
