Support the site. Your contributions keep this site running.
63mm long, 5mm shaft, 16mm thread length... not sure about the thread pitch, I lost my gauge some time ago and haven't replaced it yet.
Did your replacement bolt fit, and if so what was the thread pitch? I've got my original bolts but have stripped threads in the shaft so probably have to go the heli-coil route.
I can get a 9 mm length helicoil with the right dimensions (M6x1.0). Would it be best to use two (cut one of these to achieve the correct thread depth of 16mm) or just use one insert? I've not used helicoils before so I'm not sure. Or is there another combination out there I haven't found yet that would be better?
