Author Topic: Hard time getting exhaust spigot screws out  (Read 1495 times)
Offline killersoundz
« on: May 18, 2012, 06:24:23 PM »
Looking grim over here. Got 4 screws out with a impact driver. Stripped 3 out and busted one off. I'll probably have to drill out bigger and tap. Weak!
My project thread:
http://forums.sohc4.net/index.php?topic=107447.0
My CB750K4 Starting up for the first time after a seized motor and rebuild!
Offline chewbacca5000
  • I polish covers!
Re: Hard time getting exhaust spigot screws out
« Reply #1 on: May 19, 2012, 06:03:07 AM »
Wow that sucks!  Same thing happened to me except the machine put in a heli coil.  If I had to do it again I would drill and tap.  Make sure you are using a quality impact screwdriver like a craftsman the Harbor Freight ones are junk.  You may be able to stay the same size bolt by progressively increasing the drill bit size.  I have done this and saved thread before.  Lots of patience here.  You could then use a tap or chaser to clean things up.
Offline bender01
« Reply #2 on: May 19, 2012, 06:42:24 AM »
Propane torch and heat it up. Try the Impact again. wedge the the head somewhere so it doesnt move around when you hit it. Good luck.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
bollingball
« Reply #3 on: May 19, 2012, 07:10:18 AM »
I think this is why Honda used studs later on. If I were you I would change over now.
Ken
« Reply #4 on: May 19, 2012, 10:07:34 AM »
What kind of penetrant did you use? How long did you let it work?
« Reply #5 on: May 19, 2012, 11:01:51 AM »
Tried a propane torch.
Although I usually use PB blaster I did not have any on hand when I got into this so I did not use it. I am not convinced it would have helped these screws anyways.
I ended up drilling and tapping out 5 of them to 3/8-16 thread and leaving the other ones intact. I'm putting a aftermarket 4 into 1 on here so I'll probably just use bolts. Whatever holds the exhaust on I don't care!
Two of my drilled and tapped holes came out pretty bad I did not keep them centered very well but it will probably hold fine, I just won't let anyone look at it up close.  8)
BTW - Anyone know what size the threads are on the stock screws here? this is a 74 cb750. I'll probably be able to figure it out in the hardware store but it wouldn't hurt to be prepared
« Last Edit: May 19, 2012, 11:04:48 AM by killersoundz »
My project thread:
72500john
« Reply #6 on: May 19, 2012, 12:43:48 PM »
kroil oil and some heat. or mix up some engine unseizer, acetone and atf, think its pretty much the same as kroil.
bollingball
« Reply #7 on: May 19, 2012, 02:25:22 PM »
I still thank studs would be a better option. You don't want to keep taking a chance screwing up the threads in the head. Just a stud nut and lock washer. From then on you can use a socket
Ken
« Reply #8 on: May 19, 2012, 02:39:40 PM »
Ken
Yeah sounds good. Do you think I can just use some all thread and cut it to length for the holes I tapped out?
My project thread:
« Reply #9 on: May 19, 2012, 11:18:41 PM »
I just installed a new set of stainless studs from a kit I got. They are threaded to different lengths on each end. The ends of the threads bottom out when going on so that depth may be an issue to deal with.
