ok guys and gals.. Recently did a top end rebuild. Tappets set, points cleaned and set, timing strobe set, ohmed out ignition coils, REBUILT carbs (stock [im assuming] jets, needles shimmed all the way up [to try to correct this lean condition], screws 1/2 turn out [also to correct lean], new plugs. The airbox is installed, the exhaust is unmodified but Im still running lean... I KNOW this because when Im cruising at any speed i have to have half choke, and at times bike wont run correctly unless im full choke. Ive checked for leaks in boots in the air path. My question(s) [this may become more questions as a type] is/are: If I rejet, should I just go up one size? or 2? Is there something else I may be missing?
I wouldnt have posted a new topic, but all of the carb/lean mixture/running like crap threads are pretty obvious as to why they are in the condition they are in (things like pod filters, open headers, and the like) but on MY bike, in MY situation everything is stock. I really dont want to have to ride around fiddling with the choke all the time... crazy little things like sometimes it wont idle without being fully choked, but then wont pull from a stop without being either no choke or half choked (this is pretty hard to do, but ive been able to get through the last few days by using my left foot to kick the choke down, left hand to work the clutch, right foot to stable the bike until i get enough momentum, and of course the right hand both does the brakes and throttle
I must look like a circus clown doing this in traffic (which i dont care how I look) I JUST WANT TO RIDE MY DAMN BIKE ALREADY!!! please folks, help
