Author Topic: Just Clicks With Starter  (Read 926 times)
Offline wedoo2
« on: May 21, 2012, 06:08:17 PM »
1980 CB750C  Electrical issue, push the starter and it just clicks.  Here is what I know, and have done, so far:
Battery is at 12.15v.  I realize that this is low and a new battery is in my future, but I feel that it should be enough to turn over the motor.  Besides I tried to jump the battery from the car and nothing. Click.
I changed the regulator / rectifier with a used one without any joy.
I cleaned, and put on di-electric grease on every contact junction, even those in the headlight.
Removed the negative wire from battery to the frame and cleaned it off to be sure I was getting a good ground.
I tried jumping the solenoid, nothing.  Except sparks.
Replaced the 30 amp fuse.  All other fuses are good.  Removed and tested for continuity.
Removed starter and it works on the bench.  Cleaned the contact point. Did not open the starter, yet.
Checked continuity of the wire from solenoid to starter.
Turned over the motor, at least counter-clockwise to be sure at least it hadn't froze.
I am at a loss of what to check next.  I realize that the reg/rect I substituted may have also been bad, but what are the odds?  Anyone have more suggestions?
Some days the sun is too loud.
Offline LesterPiglet
  • 1977 CB550F2
Re: Just Clicks With Starter
« Reply #1 on: May 21, 2012, 06:16:15 PM »
Solenoid is the problem. When you bridge those contacts it should turn the starter. Try giving it a tap or two, it may be just being lazy.
Offline wedoo2
« Reply #2 on: May 22, 2012, 02:09:48 AM »
I always thought that when you bi-passed the solenoid and the motor didn't turn, then you have problems elsewhere.  I am going to replace the solenoid today and get a new battery and see where I am.
Offline uthinkimodd
« Reply #3 on: May 22, 2012, 10:40:23 AM »
If the solenoid is clicking you have a good working primary side (small wires) is working.
you need to check the secondary side.
you need to check that you have VOLTAGE going to the solenoid from the batt.
voltage to the starter from the solenoid with start button pushed.
and good connection to ground from the starter to chassis.
kep in mind if your battery is toast it may not supply sufficient amperage to turn over the engine. however it could still function on the bench.
« Last Edit: May 22, 2012, 10:44:15 AM by uthinkimodd »
