Author Topic: Hello, first time Honda owner here.  (Read 1163 times)
Offline JamesM
« on: May 22, 2012, 02:06:36 PM »
Hey all, I recently picked up a '73 CB500 Four for my "daily rider."
The thing runs great, only problems are the #3 carb is leaking like a SIV out of the bowl... Question: Will these gaskets work? It says they're for a 500K? Well... the site said I'm not allowed to post external links. So... they're on PartsNMore's website. It says they fit a 500K. What is the K designation, and will they fit my carbs?
And my other problems are the front brake is rubbing. I take it I need a rebuild kit for the wheel cylinder?
Lastly, My starter solenoid is shot... I don't really care as I'm used to kick starting but I would like it to be operational. Where can I get one?
Thanks in advance. This site is a great tool and wealth of information on these bikes.
-James
Current Stable:
1972 CB750
1973 Shovel
1978 CB750
1977 KZ750T
1996 Shadow VLX
Offline LesterPiglet
  • 1977 CB550F2
Re: Hello, first time Honda owner here.
« Reply #1 on: May 22, 2012, 04:48:28 PM »
Welcome.
First thing is download a workshop manual. There are links on this site. Do a search   ::) The usual search is broken at the minute so use the google on the left.
CB500K is the model of the bike. It has four cylinders  ;D
As for the brake, disassemble and refresh everything is a good idea if you want to know you can stop.
Is the carb leaking or overflowing? Carbs can "leak" for a number of reasons, let's narrow it down. Carbs may need a thorough cleaning depending on how used the bike is/was.
You don't have enough posts to post external links.
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #2 on: May 22, 2012, 07:09:57 PM »
Welcome!  When you can, gives us some pics of your "new" bike.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline JamesM
« Reply #3 on: May 23, 2012, 07:44:04 AM »
Thanks Lester, I downloaded the manual.
My leak is coming out of the the top of the float bowl because of a bad gasket.
So a '71 is a 500, a '72 is a 500K1, and a '73 is a 500K2?
That site with the float bowl gaskets claims the gaskets are for a 500K, there are parts for 500s... then 500Ks separately. I would imagine Honda used the same carbs on them all three years?
I'll get some pictures once I get it put back together, I have half the bike apart right now.
Current Stable:
1972 CB750
1973 Shovel
1978 CB750
1977 KZ750T
1996 Shadow VLX
  • 1977 CB550F2
« Reply #4 on: May 23, 2012, 02:09:07 PM »
This should help as far as models are concerned.
http://www.sohc4.net/index.php/cb500/
Offline JamesM
« Reply #5 on: May 28, 2012, 03:58:49 PM »
Alright, got the model designations figured out. Got my new float bowl gaskets ordered also. Should be here Wednesday, and I'll will be cruising.  :D
The past few days I tore bike down, stripped all of the rust and crust off of it and hit some parts with gloss black. This thing was a rust bucket.
Still to do: Rebuild front brake, wrap exhaust and get different ends, as they are ugly. Fab up some mounts for a smaller headlight, and front turn signals. Then fab up a new taillight, plate holder along with turn signals.
Then I'm just going to cruise her as God intended. Down the road I'd like to get lowering springs, some drag bars, and some Avon speedmaster tires. Other than that I'm going to keep this bike relatively stock which is a new concept for me.
Before:
After:
With my girlfriend's 'new' '78 Twinstar.
Current Stable:
1972 CB750
1973 Shovel
1978 CB750
1977 KZ750T
1996 Shadow VLX
Offline Really?
« Reply #6 on: May 28, 2012, 05:37:45 PM »
Welcome to the forum.  I figure if you narrow down your location a bit closer to where you live other than the United States, you may find some hands on help local to you.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline JamesM
« Reply #7 on: May 29, 2012, 05:22:17 PM »
I am from Saint Marys, Pennsylvania.
Welp, got my new float bowl gaskets in the mail today. Threw them in carb #3 and 4, got it all buttoned up and was so excited to ride it as I just plated and insured it today and what do you know?! Still leaking like a bastard. Sigh.
Current Stable:
1972 CB750
1973 Shovel
1978 CB750
1977 KZ750T
1996 Shadow VLX
