I'm fitting the CR's and could use a little expertise from those of you that have been there before me
Fuel line stuff - there's been much debate/info about fuel line sizes with the CR carbs. Our stock fuel line size is 5.5mm while the carb inlet is ~ 6.5mm. Guys have been trying to find adapters, etc. I just returned from my Honda shop with some new soft 5.5mm hose.
Guys, this 5.5mm goes onto the carb inlet just fine, no adapter necessary. Don't beat youself up over this!It is a very tight fit but it works. I hung the end of my 5.5mm line over my shop light bulb and heated it so that it would stretch over the inlet. A little heat, a little twisting and pushing - viola, it's on. Fits good.
Now, what I'd like to pick the brain trust about is all the inlets. Again, more debate/info. There are inlets between pairs of carbs with the center one open and ready to acept my 5.5mm fuel line so I went with a single line for my single line petcock and left the other 2 alone.
SO, pray tell, what is that fuel line looking fitting on the outside of #1 below the choke lever?? Does it need to be tubed or left alone as is? Plugged perhaps? End of my fuel line stuff
On to throttle cables......
I'd really love to make my stock 75/76 CB750F cables work! Has anyone managed to make this happen? I've learned through the search function and playing that it is imperative to install both cables prior to installing carbs. VERY understandable. However the search function yields differing results. I need to take the carbs off from my test fit to install the 1/8" brass sync ports and HOPE to only have to put them back on one time! I know you're saying "yeah right, good FN luck!". PLEASE help me make this happen.
Thanks to all contributors
