Now that the thread is gone, it won't help much, but I'll post anyway.
The thing is rotor pulling has little to do with muscles or force (if applied continuosly) but with impulse, impetus, momentum.
The change in momentum, called the impulse, is equal to force times the change in time.
The crank shaft has to be prevented from moving only the slightest tad as this will weaken the impulse.
It is not enough to apply break and gear (numerous dampers in rear wheel, clutch, prim.shaft)
The rear axle if (threading/size correct) can work sometimes, but actually it is too long and the material it is made of is too weak , so it will twist (torsion) and eat up the impulse. Also a 20+ year old axle most often is in bad condition, the end in not 100% planar anymore, the thing will tilt, ruin the threads, the rotor will be unimpressed. Use a rotor puller, or a hardened bolt (made of steel) of the correct size.
So how does it work. Apply WD40 or similar to the opening of the rotor, and make shure it is clean.. Screw in (to screw it in, use something that has no moving parts, no ratchet, a T shaped tool is good) the proper tool (rotor puller/hardened bolt) until it sits firmly but not too hard, as to not to ruin the threads.
Use a heavy plastic sledge and firmly and straightly pound on the T.
If threads are gone, a three legged puller to build up tension between crank shaft and rotor evtl. in combination with temperature (ice spray on crank shaft/MINI acetylene torch on rotor) might do it, but it has to go fast, and you have to be careful to not set that thing on fire!
