Author Topic: SOHC archeology again, found a large cam.  (Read 1870 times)
« on: May 26, 2012, 09:43:25 AM »
I was digging through my brothers parts, checking cams to see how consistent the lobe sizes were, there was a very shiney one. I checked it, it's a welded stock core. The intake measures 1.460 just by putting a caliper over the high spot, compared to his RC315 cam which calipered 1.420 that's a major big lift, I'd say.
 The only non stock  marks are K/H  F stamped on the end.
I'll need to set up a dial indicator in an old head to measure the auctual lift, I've got a degree wheel, maybe I can get the duration too. I've got some learning to do.
« Last Edit: May 26, 2012, 09:54:23 AM by Don R »
Re: SOHC archeology again, found a large cam.
« Reply #1 on: May 26, 2012, 09:46:39 AM »
 Those specs are around in with Magacycle I think..can I have it ?
 Bet you are not afraid of high lift..lol...
« Reply #2 on: May 26, 2012, 09:50:03 AM »
Shouldn't have told my brother what it is. Really I'm doubtful he will let it get away. thanks for the tip I'll check there. I want the RC315, so does he.
I don't see anything obvious in megacycle but did notice they measure duration starting at .040 lift. Good to know, is that standard for our cam manufacturers?
« Last Edit: May 26, 2012, 10:00:58 AM by Don R »
Online Tim2005
« Reply #3 on: May 26, 2012, 12:05:42 PM »
I suspect the KH F marking means it's a Kenny Harmon F grind:
http://www.satanicmechanic.org/kharmoncam.shtml
« Reply #4 on: May 26, 2012, 02:54:08 PM »
Thank you. That makes sense. I put a dial indicator on the lobes and got .370" intake and 330" exhaust. Are our rocker arms 1:1 ratio?  The kenny harmon cam reads .385" and .330" that doesn't mean it isn't a KH. This was my first go round measuring a cam in one of these engines.
« Reply #5 on: May 26, 2012, 04:29:13 PM »
 Did you find the specs ? they are listed with another makers list.. have it on my desk at the shop..I think I have an F it describes as good for TQ midget racing...
« Reply #6 on: May 26, 2012, 10:18:54 PM »
.385 @ 295 int and  .330 @ 290 exhaust? I know it's big.  My brother once bought a 1,000 kitted engine it may have come with that one. The Satanic Mechanic link above mentions road racing too.
« Reply #7 on: May 26, 2012, 11:18:35 PM »
 I think a 315 has .375 on each valve.. and 310 degrees duration. but checking duration at .050 opening brings it in around 280 or 290 duration..
« Reply #8 on: May 27, 2012, 11:10:17 AM »
Thanks, 754 I didn't try to measure the 315 yet. I assumed it would be smaller.
