Author Topic: paint help  (Read 800 times)
Offline wardenerd
  • '77 550F '81 650C
paint help
« on: May 26, 2012, 10:56:03 AM »
after two weeks dry time I rubbed my k2 paint and clearcoat that was really clear and shiny with 3000 wetdry with water and a drop of dawn. Turtle wax and  The finish is now slightly hazy.  What can I do to fix this?  compound, suicide what?
Offline Rigid
  • She likes a
    • KingCustomCycles
Re: paint help
« Reply #1 on: May 26, 2012, 11:25:18 AM »
McGuire (spelling?) makes a polish just for removing that haze.  Called fine cut.
Offline LesterPiglet
  • 1977 CB550F2
Re: paint help
« Reply #2 on: May 26, 2012, 11:26:11 AM »
First. Why did you rub it down after the final coat? This isn't necessary if the final coat was shiny. Try some fine rubbing compound like Meguiars.
http://www.meguiars.com/en/professional/products/
Offline Gordon
  • 750K1, 550K2
Re: paint help
« Reply #3 on: May 26, 2012, 11:26:35 AM »
After wet-sanding you need to use a power buffer and real polishing compound, like Meguiar's.  Save the Turtle Wax for after you've gotten the finish flawless to help protect it.
edit:  looks like Rigid beat me to it. :)
Re: paint help
« Reply #4 on: May 26, 2012, 09:56:22 PM »
Meguiars has good products, but I prefer Griots.  You want a good rubbing compound after 3000 wet sanding, followed by polishing compound, then a good swirl remover. Use a rotary buffer on low speed to prevent burn through. keep it moving.
Wait at least a month before any waxing.
